Gary,
I just went through the same thing. I tried in vain for hours to press the links on the bar in the car and no-o-o way. I then approximated the correct position (no way to be perfect), pressed the ends on out of the car, and then threaded it back in. There is a *lot* of flexibility in those rubber joints, both rotationally and laterally, which you need every bit of to get it back in. It took a few tries to manage that too. It seemed impossible, but it did work out, and no bits removed other than the bolts for the sway bar.
Harold
1969 1750 Spider Veloce
Austin, TX
