Installing the new flywheel and pressure plate this weekend. Here are the weight savings with the new Aluminum Flywheel from Santos Italian Car Service in Northridge CA..
Both pressure and clutch plates are 'Sachs' brand items. The old steel parts may be original. Interesting to note, the new clutch plate is 3/4 of a pound lighter!
The new Aluminum Flywheel is made up of a steel toothed ring gear for the starter to chew on, and a steel wear surface for the clutch plate to pancake with. As far as I'm concerned, it is the Mona Lisa of lightweight flywheels. There may be better/lighter ones out there, but this is the one I have and I am in love!
1981 Alfa Spider Veloce
Old:
Steel Flywheel = 22.00 lbs
Sachs Pressure Plate = 10.00 lbs
Pressure Plate Bolts = 1.50 lbs
Assembly w/bolts wo/plate = 33.50 lbs
Sachs Clutch Plate = 2.75 lbs
(Assembly w/bolts w/plate = 36.25 lbs)
New:
Aluminum Flywheel = 8.50 lbs
Assembly w/bolts wo/plate = 20.00 lbs
Sachs Clutch Plate = 2.00 lbs
(Assembly w/bolts w/plate = 22.00 lbs)
A 13.5 lbs weight savings is enormous for that rotational mass. The counter-balance weight was added, and widow marked, on the pressure plate.
Old:
New:
