OK, now the complicated bit:
1st RESIST ALL URGES TO PUT THE KEY IN AND TURN IT, PULL IT, OR TOY WITH IT IN GENERAL. ALL YOU'LL END UP WITH IS FREAKISHLY TINY TUMBLERS AND SPRINGS ALL OVER THE ROOM.
2ND See #1
Using your jewelers screwdriver, gently prise up the end of the tumbler retainer plate furthest from the key end.
Don't get all happy and lever it back on itself, it's in a groove and meant to slip out the end rather than come up off. All you're after is enough to grip it with the needle nose pliers.
With the tumbler holes facing down, slowly and carefully start pulling the retainer plate out toward the back of the lock.
Once you clear the 1st (closest to the key) tumbler hole, a small flat on both ends tumbler will pop out by just a tiny bit.
Remove it and with luck the spring and key tumbler (pointed on one end) will follow. (if not, gently rap the lock on the table and they'll drop out)
Repeate for each of the 5 tumbler assemblies. (note that pic only shows 2 of the 5 sets to give an idea of the different sizes and shapes involved. ALL of the springs are the same size, it's the tumbler bits that are different form position to position and key to key)
IT IS IMPERATIVE THAT YOU KEEP THE TUMBLERS MATCHED AND IN ORDER UNLESS YOU WANT TO RE-KEY YOUR LOCK OR FEEL LIKE FRIGGING AROUND FOR HOURS MIXING AND MATCHING PARTS TO GET IT TO WORK AGAIN.
Once all the tumblers are out and sorted, pull lock cylinder out of the housing and the key retension cam will drop out (it's job is to keep the key in the lock once the key is turned) along with the column interlock (which may or may not drop out on it's own without removing the cylinder depending on grease, wear, phases of the moon and a couple other variables. (they both fit in only one way so reassembly is easy to figure out if they just go flop on you)
Reassembly is pretty straightforward reversal of process, using great care to get the right bit of tumbler in the right spot (the pointed bit of the key tumblers point at the key) not kink springs or shoot parts across the room (they should be under very low pressure and not do so anyway, but I'm not gonna take the blame if it happens) while slipping the tumbler retainer plate back in one hole at a time, (you may wish to tap the plate down/flat in it's groove again. It won't hurt to do so, but don't get carried away and mash the crap out of it) and making sure the cam that runs the electronics is correctly orientated.
You'll likely have to fiddle the column lock parts together as they get real floppy and loose without the shroud in place.
Do NOT reinsert the key into the switch until the cam section is screwed back on, otherwise you risk dumping tumblers again when the lock cylinder tries to fall out while you're working.
To re-key to a different key than the switch was made for, you'll have to do a combination of shuffling tumbers (both parts) and possibly modifying (by filing) existing stuff, or outright making custom fabbed ones out of thin brass rod. (small bore brazing rod works well)
