Old 08-09-2008, 01:46 PM
new2alpha's Avatar
new2alpha new2alpha is offline
Driveshaft support & bearing replace both?
Is it necessary to replace the entire Driveshaft Center support or can I replace the bearing in my current support? Honestly, the bracket on my '71 looks better than the ones I see in the parts catalogues.
Old 08-10-2008, 06:09 AM
WopJob's Avatar
WopJob WopJob is offline
Usually the rubber part breaks before the bearing necessitating the change in the first place. When I did mine on my '87 I changed the support with a new bearing only becaus e the old bearing is a pain to remove from the old support. If you have a press you can attempt to change the bearing otherwise it would be easier to change the support and bearing. just my opinion.
Tony G. in NJ
87 Graduate - Calimero '90 Toyota Tercel - Babbaluci
