#16 (permalink)
Old 08-15-2008, 07:29 PM
new2alpha's Avatar
new2alpha new2alpha is offline
Timken bearing photo
see attached photo. FAG on left-- Timken on rt. From the bottom of the race to the outside of the bearing is a greater distance. What extends past the race does not matter as this is inside the hub.
  #17 (permalink)
Old 08-15-2008, 07:31 PM
new2alpha's Avatar
See attached photo. Timken is thicker from bottom of race to outside of bearing. Overall bearing is thicker but most is inside the hub. I believe all that matters is the distance from the bottom of the race to the outside of the bearing
  #18 (permalink)
Old 08-15-2008, 09:53 PM
John Davison John Davison is offline
front wheel bearing part numbers
I don't know if it makes a difference, but the Timken listing is for a 30206M. Did you get the one with the "M" as part of the number? Perhaps it does not matter?
John
  #19 (permalink)
Old 08-16-2008, 08:07 AM
new2alpha's Avatar
Found the rpoblem. one bearing has 20306/20306M printed on the box. The second bearing has 32206/20306M on the box. on the second bearing the 30206M is hand written. I did not notice until you asked. The bearing are different. The first bearing is a match. The second is the one I posted the picture of. BACK TO AUTOZONE!!!!!!!!!!!
  #20 (permalink)
Old 08-18-2008, 10:00 AM
CarlosSpider's Avatar
CarlosSpider CarlosSpider is offline
I have used the SKF kit two times and I can say that these kits fits ok.
Carlos
Alfa Spider Veloce 2.0
