08-10-2008, 09:32 AM
Originally Posted by ghnl
No. The two round vents on the top of the dash just snap in & out. The ducts between those and the top of the heater unit are like small clothes dryer vent tubes. But that is about all you can remove without removing the dash.
Does your car have A/C? The A/C unit is completely seperate from the heating unit. They are not integrated into one like most cars. The A/C ducts are similar and could be removed & washed if needed. I'm not sure about the rest of the A/C unit.
I am very acquainted with the two round louvered vents as the rim seat is quite sharp. Ouch!
I see two ribbed and flexible plastic, rubber or vinyl hoses below the removed louvered vents. These are the ones I can remove, clean and replace without removing the dash?
Joe
1990 AR Spider Graduate
