Hey all,
Half asleep here BUT wanted to let you know what has become of my car lately!
So I took my 84 to this shop that was recommended in the CO thread a bit ago - Apple Motors. They specialize in Fiats but do also work on Maseratis, Lancias, and Alfas. In fact they were doing a clutch job on a '69 spider when I walked in. Great guys, great prices, honest.
Turns out my car really is in better shape like I thought! The HG isnt bad! They pressure tested everything and there were no leaks. The oil in the radiator must have been left over from a different time in the car's life.
They did retorque the head and hopefully that should get rid of some of the oil coming out on the back of the engine on the exhaust side between the head and block. He torqued the back down a few extra lbs to 70 to see if thatll stop the light leak.
They also flushed the radiator which turns out didnt have nearly as much oil in it as I originally had thought.
The only bad news was that because of the fan belt that was too big that was installed by the first mechanic in CA when I bought the car, my waterpump is starting to go out. The belt was so tight it put stress on the water pump and made it wear ugh. So there is play in the shaft BUT there arent any leaks yet and its not humming too much. Enrique - that must be what was humming off and on on my drive home from CA
I have my new/used top/frame on the way from a fellow forum member and Im super excited to get that on the car.
Im really torn about what I should do with the car now! I really love this car ugh.
Also, they didnt find any real vacuum leaks which is good but I know theres something somewhere!
The car now has racing Amsoil 20/50 in it - wish me luck that I dont start to have all sorts of leaks now haha!
OOhh one other funny tidbit for this installment - For the longest time I thought the little knob for rolling back the tripometer was broken off. Instead, the problem was that I was pushing on a screw under the dash instead of finding the actual knob
- Problem solved! haha!
Im half asleep but thought I'd post this!
Jeff
