Connecting the horn - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 05-19-2017, 08:50 PM Thread Starter
Connecting the horn
I have the feeling my first post on the BB will be a stupid question, but I need some help. I removed the dash to get to my faulty oil gauge. In the process I removed the steering wheel. The red wire that goes from the wheel to the inside of the steering column disconnected easily at the bullet connector that is about 5cm inside the shaft. My problem now is I don't know how to reconnect it.
Any help greatly appreciated.
DUE770 is offline
post #2 of 3 (permalink) Old 05-19-2017, 09:08 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
Go to the steering box and push the wire up or use a
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #3 of 3 (permalink) Old 05-19-2017, 09:26 PM Thread Starter
Thumbs up
Pushing from the steering box worked perfectly. Thanks!
DUE770 is offline
Replace with
