Re: clutch bleed.. - Alfa Romeo Bulletin Board & Forums
 10Likes
post #1 of 18 (permalink) Old 05-16-2017, 11:31 AM Thread Starter
adamreed31's Avatar
Re: clutch bleed..
Hello again.
Recently I bled the brakes on my s3 spider simply because the pedal seemed a bit spongy and fluid looked pretty murky- Lord knows how long that fluid has been in there! ( I have only had car a few months).
With that, now I'm focusing my attention on my clutch fluid. The reservoir again looks like the fluid is pretty ancient/murky. The clutch seems to be operating properly from what I can tell.
Would it be advisable to flush this murky fluid like I did with the brakes as good maintenance or am I about to open up a can of worms/potentially doing more harm than good? I would think a good fresh fluid flush would be good...
Finally, what is the most effective procedure to bleed the clutch out?
Thanks in advance!
Adam
If you can't change the people around you, change the people around you.
Currently: 87 Spider Veloce. Previously Owned:'79 Alfetta GT,'80 Lancia Zagato, 86 Gtv6
adamreed31 is offline
post #2 of 18 (permalink) Old 05-16-2017, 11:52 AM
sloboy89's Avatar
Bleeding the clutch is easier than the brakes. People use different techniques, including old-fashioned one-person in car pushing the clutch with the other working the bleed valve on the slave cylinder. I've used a Harbor Freight bleeding tool (compressor driven) with success, and others use the reverse-up technique where fluid is pushed up from the slave cylinder. If the fluid is black, it should be replaced.
adamreed31 likes this.
Rich
'85 Spider Veloce
sloboy89 is offline
post #3 of 18 (permalink) Old 05-16-2017, 12:14 PM
Alfajay's Avatar
Yes, replacing the old clutch fluid is worthwhile, and as sloboy89 writes, it isn't difficult. The only circumstance I can think of where doing this procedure would be "open up a can of worms/potentially doing more harm than good" would be if the bleed screw on the slave was rusted in place, causing it to shear when you tried to back it out.
You can save a little time by using a turkey baster to remove the cruddy fluid from the clutch reservoir (*). Take out as much as you can, re-fill with new fluid, and bleed. It shouldn't take long until clean fluid is coming out the slave cylinder.
*) Make sure not to drip any brake fluid onto your car's paint - the stuff makes great paint remover!
'63 Guilia spider
Alfajay is offline
post #4 of 18 (permalink) Old 05-16-2017, 12:18 PM
Registered Member
mcola's Avatar
Also make sure the bleeder is at the top (12 o'clock). I say this because the slave can actually rotate in its housing.
Mike
'87 Quadrifoglio
mcola is offline
post #5 of 18 (permalink) Old 05-16-2017, 01:02 PM Thread Starter
adamreed31's Avatar
can one just turn the housing to orient the bleeder in the 12 o clock orientation that easily? forgive me..where exactly is the bleeder located? pic? appreciate you all! think i'll try the reverse bleed in this case...
post #6 of 18 (permalink) Old 05-16-2017, 01:19 PM
sloboy89's Avatar
The slave cylinder is held in place by two circlips that fit in external grooves around the body of the slave cylinder, and thus, it can rotate. When bleeding, you just need the bleeder valve to be at the top. Below is a picture of the slave cylinder showing the bleeder valve on the right side (uses a 7mm wrench if I recall). (You can see the two grooves on the housing for the circlips).
Rich
'85 Spider Veloce
sloboy89 is offline
post #7 of 18 (permalink) Old 05-16-2017, 01:20 PM
spiderserie4's Avatar
sometimes the slave is well stuck, but other times it will easily turn....
here is a photo, you can just see the bleeder nipple peeking out above the flexible hose, its at 12 o'clock as here, it is photographed from below looking up.
Bleeding the clutch: Am I doing it wrong or is my clutch slave cylinder bad?
spiderserie4 is offline
post #8 of 18 (permalink) Old 05-16-2017, 01:57 PM Thread Starter
adamreed31's Avatar
Thanks again all...everyone is so helpful/accommodating! Does it matter if the bleeder nipple is 12 or 6 o clock if I use the reverse bleed method? I have had such better luck with reverse method in past thinking that air likes to go up/not down...
post #9 of 18 (permalink) Old 05-16-2017, 02:23 PM
nealric's Avatar
Probably not quite to the same degree, but it couldn't hurt. I like the pressure bleeder method myself (motive et. al.). Very simple process.
nealric is offline
post #10 of 18 (permalink) Old 05-16-2017, 02:30 PM Thread Starter
adamreed31's Avatar
'nealric'...pressure from below at nipple or from above at reservoir?
post #11 of 18 (permalink) Old 05-16-2017, 02:33 PM
nealric's Avatar
Above from the reservoir. Not sure how you would bleed the air out of the system if you applied pressure from the nipple. I've only heard of vacuum being applied from the nipple side.
1986 Spider Veloce Turbo
nealric is offline
post #12 of 18 (permalink) Old 05-16-2017, 02:39 PM
sloboy89's Avatar
Here's Eric's post on the reverse-bleeding procedure:
86 Spider Master clutch bleeding
Rich
'85 Spider Veloce
sloboy89 is offline
post #13 of 18 (permalink) Old 05-16-2017, 02:44 PM
nealric's Avatar
Note that he's applying fluid, not pressure. The only issue with that method is that you need to ensure an airtight seal with the nipple and probably want a friend there to let you know when you've put in enough.
nealric is offline
post #14 of 18 (permalink) Old 05-16-2017, 03:00 PM Thread Starter
adamreed31's Avatar
nice. I'm on it! the only luck I had bleeding an old school saab 900 clutch was in this way. will post with results. thanks again!
post #15 of 18 (permalink) Old 05-17-2017, 10:00 PM
I had to reverse bleed my clutch master cylinder. I use a pressurized brake bleeder and it worked great. You can buy one from Motive Products 0100 for around $50.00.
kuni123456 is online now
Replace with
