Duetto Rear Trans Mount ? - Alfa Romeo Bulletin Board & Forums
 1Likes
post #1 of 16 (permalink) Old 05-12-2017, 03:01 PM Thread Starter
oldcanuck's Avatar
So a few weeks ago when my tech was installing new Miller's Classic Green gear oil in my trans, he notices that the rear trans mount looks poor at best. He recommended that we change it the next time up on the lift, so I ordered a new replacement mount from Classic Alfa in my last parts order.
For the last couple of years, I had noticed a bit of a growl from 5th gear occasionally, 1 thru 4 smooth as silk, no noises whatsoever. So I figure, maybe since my rear mount was bad, AND 5th gear is at the rear of the gearbox, maybe that is where my periodic 5th gear noise was coming from.... hey alignment is everything sometimes, right.
So this morning we change out the mount.... so on the way home...... 5th gear is now also smooth as silk... no noise or growl at al.... BUT I now have a bit of a vibration under the car at all times..... like the drivetrain is now back in alignment and the car doesn't like it ! My tech previously has checked my motor mounts and driveline doughnut and gave me the thumbs up..... so what gives ?
Let me know what you think, and thanks in advance.
Bob
1966 Duetto
1976 Spider Veloce
oldcanuck is offline
post #2 of 16 (permalink) Old 05-12-2017, 03:29 PM
flivesay's Avatar
How is your middle drive line bearing? Maybe the bushing in it went soft like the rear mount? Now the tail of the tranny is stable and the bearing bushing is taking up the slop--or not. Was the new bushing identical to the old one? On some bushings the center pin hole sits higher or lower than the original throwing everything a little out of alignment. Just a couple of thoughts from your description--
Frank Livesay Huntsville, AL
Green Alfa - 68 Canadian 1750 Spider Veloce (driver)
White Alfa - 68 Euro 1750 GTV (needs a refresh)
flivesay is offline
post #3 of 16 (permalink) Old 05-12-2017, 06:52 PM Thread Starter
oldcanuck's Avatar
Middle drive line bearing and support was replaced 90 days ago....when the trans oil was dumped.
We didnt compare the trans mounts.... bagged one that came out was almost in pieces. Ordered the correct early 105 variant from Classic..... I assume their parts are well known/used all over. I have used quite a few parts and components from them over the years with zero issues. I do recall the cross member bolt lined up pretty close, and we did make sure the mount was oriented the correct way before pressing in.
1966 Duetto
1976 Spider Veloce
post #4 of 16 (permalink) Old 05-12-2017, 07:54 PM
flivesay's Avatar
Yeah I haven't had an issue with classic parts. The old mount was probably taking the vibration out because it was so loose and now you can feel it in the tranny. I hate driveline vibrations. U joints? Sometimes they feel good from an inspection while installed but one of the cups dried out and causes vibration. And then there's ujoint out of phase. Did you break down the driveshaft when installing the mount?
BTW--did changing out the gearbox oil fix the problem you had with redline?
flivesay is offline
post #5 of 16 (permalink) Old 05-12-2017, 08:00 PM
The mechanical clutch cars use a stiffer mount than the later hydraulic cars. It allows less movement of the tranny but it is less tolerant of driveshaft misalignment. I have one in my 79 and in my opinion it is an upgrade but I had to spend a few hours measuring and correcting misalignment that was not apparent with the soft mount.
85 GTV6 3L
alfaparticle is offline
post #6 of 16 (permalink) Old 05-13-2017, 06:45 PM Thread Starter
oldcanuck's Avatar
Yes... but had to flush twice and now running Miller Classic Green Gear oil..... back to normal.
Bob
1966 Duetto
1976 Spider Veloce
post #7 of 16 (permalink) Old 05-13-2017, 06:49 PM Thread Starter
oldcanuck's Avatar
No did not break down the driveshaft when installing the trans mount.... but it was when the center support and bearing were changed not long ago.
I drove the car almost 100 miles to a show in the mountains today..... under 3000 rpm its not too bad.... above 3000 is another story.... but I agree, its somewhere in the drive line.
How can I be sure ?
1966 Duetto
1976 Spider Veloce
post #8 of 16 (permalink) Old 05-15-2017, 03:43 PM Thread Starter
oldcanuck's Avatar
UPDATE
I have driven the car a couple more times.... and the vibration is lessening, and the rpm range where there is a little remaining vibration is increasing....... it trying to go away on its own.
Is this possible......?
1966 Duetto
1976 Spider Veloce
post #9 of 16 (permalink) Old 05-15-2017, 04:24 PM
not2old4toys's Avatar
Probably not!! Back to basics. Just because it was changed awhile ago doesn't mean that it can't be at fault. Rear/front wheel balance, u joint play, driveline out of balance, carrier bearing, flex donut, transmission mount. All need to be check for correctness.
Cheers, Jon
not2old4toys is offline
post #10 of 16 (permalink) Old 05-16-2017, 07:07 AM
Richard Jemison
Alfar7's Avatar
Vibration
Several things have to be correct or they will cause vibration.
1- the driveline must be "in line" and often the engine & transmission isn`t aimed directly at the pinion flange. Correct by shimming the trans in the correct location. Pics of how to check this have been posted on the BB.
2- the pinion angle MUST match the angle of the front section of the drive shaft to phase the u-joint`s movements correctly.
3- the u-joints should be correctly aligned. If the splined joint was separated this could be the problem. There is only 1 correct fitment in this part, but it can be assembled in multiple incorrect positions.
alfaparticle likes this.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #11 of 16 (permalink) Old 05-16-2017, 08:00 AM
IRONBLOCK's Avatar
Originally Posted by oldcanuck View Post
UPDATE
I have driven the car a couple more times.... and the vibration is lessening, and the rpm range where there is a little remaining vibration is increasing....... it trying to go away on its own?
Probably not but this is the least expensive option. I'd give it a couple of thousand miles to see if the vibration continues to lessen.
Mark
IRONBLOCK is offline
post #12 of 16 (permalink) Old 05-16-2017, 01:46 PM
spiderserie4's Avatar
first thing I'd do in your position, is get under the car and check the alignment....as others suggest above!
diagram here that illustrates it:
Gearbox mount orientation
oh, and, don't forget to grease the slip (splined) joint...frequently, I do it every oil change at latest
spiderserie4 is offline
post #13 of 16 (permalink) Old 05-17-2017, 04:53 AM Thread Starter
oldcanuck's Avatar
I do know the splined joint on the driveshaft was marked prior to splitting apart to install the new center support and bearing. It has received a once a year greasing at minimum while I have owned the car.
Since this vibration continues to lessen... I am going to give it a little more time, but first chance I have to get it back up on the lift, I will have Skip check alignment of the driveline since I'm sure this is where the vibration originates from.
I think I am going to re-new the center muffler here soon, so this would be a perfect opportunity to check it.
I appreciate everyone's input.
Bob
1966 Duetto
1976 Spider Veloce
post #14 of 16 (permalink) Old 05-18-2017, 07:33 AM
How is that mount replaced with the transmission in the car? Is there a tool that "presses" the bushing out within the tranny tunnel? thx.
hoodmeister is offline
post #15 of 16 (permalink) Old 05-18-2017, 08:27 AM
yes, the special tool seen here:
Replacing transmission mount
but a few things from the local hardware store does the same job!:
Trans mount
Replace with
