Alternator Problem - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 03-20-2017, 11:15 AM Thread Starter
dj91alfa's Avatar
Alternator Problem
My S4 spider will frequently have a squeal from under the hood. At that time the all dash lights will come on and the radio will go off. Also, the voltage gauge will peak to max.
Would this indicate an alternator problem or possible wiring problem?
dj91alfa is offline
post #2 of 5 (permalink) Old 03-20-2017, 11:56 AM
spiderserie4's Avatar
How is the alternator charging? Put a voltmeter across the battery poles with engine ticking over: what voltage do you get? (don't go by the dash gauge for this)
Check battery ground is tight, also where it bolts to the trunk floor.
voltage regulator? it might even squeal if the brushes are really worn....
it is screwed in the back of the alt. itself, comes out easy with 2 screws (easy to get to, if you take off the air cleaner top half)
do a visual check, see if the brushes are long enough, and of even length, or oily perhaps...or worn right down.
Orig. Bosch regulator (Bosch 1 197 311 028) is probably 30$ to replace, same as Audi, BMW, Volvo what have you...
spiderserie4 is online now
post #3 of 5 (permalink) Old 03-20-2017, 12:12 PM Thread Starter
dj91alfa's Avatar
The voltage on the battery is 12.6V prior to starting.
The voltage across the battery is approx. 13.6v when started.
I have seen it spike up to 18v while running.
Thanks for your help.
dj91alfa is offline
post #4 of 5 (permalink) Old 03-20-2017, 12:23 PM
those are all good values.
......except the 18V spike! thats a bad'un!
I'd get the alternator checked (Autozone do that for free, don't they...hoping you buy one of their alternators!....
could try the regulator first, but could well be a bad alt. diode.
post #5 of 5 (permalink) Old 03-20-2017, 01:37 PM
Alfajay's Avatar
Yes, all true.
The key is to do something NOW. 18V is high enough to damage your EFI computer, radio, and anything else electronic. Is the tachometer electronic in an S4? If so, that could get fried too.
'63 Guilia spider
Alfajay is offline
