Vin's S4 Transmission Rebuild for Dummies - Page 2 - Alfa Romeo Bulletin Board & Forums
 9Likes
post #16 of 133 (permalink) Old 03-19-2017, 12:46 AM Thread Starter
Vintre's Avatar
Using a 12mm socket, loosen the bolt
Remove the bolt/tab/alignment washer
Here are some nice pictures I found on the BB
Here we can see the alignment tab and fork are grooved. This helps us later.
Vintre is offline
post #17 of 133 (permalink) Old 03-19-2017, 12:52 AM Thread Starter
Vintre's Avatar
Now you can pull the shift rod out.
Remove the fork
Now you can remove the mainshaft.
Here we can see that in my S4, there are no O rings to be changed mentioned in other threads. As well, we can see the jelley bean or peanuts or ????. If you aren't removing the other 2 shift rods and forks, you don't need to worry about these. Somehow 1 fell out on me and I was lucky to find it on the bench, so we will see how they come out and go back in later.
Vintre is offline
post #18 of 133 (permalink) Old 03-19-2017, 01:15 AM Thread Starter
Vintre's Avatar
Remove the input shaft / 4th gear by just pulling it straight out
4th gear bearing. This might stay on the shaft, like mine, or stay in the 4th gear but find it and store it safely.
Move the input shaft / 4th gear to a bench vise so you can work on it. I know, I need to buy vise jaw protectors.
And here we have the ever famous, dreaded, large snap ring found on every gear except reverse. Note that one end is flat and the other has a tab or an ear. We use the tab/ear for removal and installation.
Vintre is offline
post #19 of 133 (permalink) Old 03-19-2017, 01:24 AM Thread Starter
Vintre's Avatar
To replace the syncro rings, you must remove the snap rings. I bought these large, straight tip, snap ring pliers from Princess Auto (Canadian version of Harbor Freight) for $15. Didn't know how they would work, but gave them a try. I was worried about removing the large snap ring as you read so much about how hard it is to remove them. I talked to papajam and he taught me a way to remove them safely and somewhat easily.
Start by spreading the snap ring, pushing the ear against gear, keeping it in the groove and lift the other side out of the groove.
Now, with your hand over the snap ring, in case it goes flying, continue to spread the snap ring just enough to keep working it around, out of the groove.
And there you have it! No fuss, no muss, no mess.
Vintre is offline
post #20 of 133 (permalink) Old 03-19-2017, 01:47 AM Thread Starter
Vintre's Avatar
Here is what that snap ring is holding in. The assembly is the same for 2nd - 5th. 1st is a little different, but we are going to change that during the 1st Gear Fix. Note the position of the quadrants ( the 2 top hat looking things). The small one is pointed into the centre of the gear and the larger one is pointing out of the syncro ring.
All the parts just lift out. Here is the outer syncro ring (cut out at 12 o'clock), the 2 quadrants, one small one large, and the 2 check straps that go from quadrant to quadrant. All parts go in the baggie for later!
Remaining mainshaft
3rd Gear end
Vintre is offline
post #21 of 133 (permalink) Old 03-19-2017, 01:58 AM Thread Starter
Vintre's Avatar
Remove the 4/3 syncro hub by just sliding it off
I borrowed this 12T press from a friend. It did the job, but I would recommend the 20T. The 12T did the job, but at times it seemed weak.
I bought a 3" gear puller from Princess Auto. It was the biggest one they had. Like the press, it was OK, but I would recommend a bigger one if you can get it.
So, onto the first press !!!!!!!!
With the olive facing up, place the puller under the reverse gear (straight cut gear).
I placed a cushioned catch bin under the press in case I wasn't able to support the shaft. After this first press, I didn't use the catch bin. I was able to support the shaft.
Vintre is offline
post #22 of 133 (permalink) Old 03-19-2017, 02:08 AM Thread Starter
Vintre's Avatar
1st pull, you get a lot of parts. Sorry I dont know all the names for each part but I kept track of each one and the order they came off.
5th gear assembly
Vintre is offline
post #23 of 133 (permalink) Old 03-19-2017, 02:11 AM Thread Starter
Vintre's Avatar
Double bearing
5th syncro hub
Syncro Ring / Reverse Gear
Vintre is offline
post #24 of 133 (permalink) Old 03-19-2017, 02:25 AM Thread Starter
Vintre's Avatar
Mainshaft at this point
Remove large Woodruff key
Place gear puller under bearing
Bearing pulled
Vintre is offline
post #25 of 133 (permalink) Old 03-19-2017, 02:29 AM Thread Starter
Vintre's Avatar
Bearing has a cap that goes in the middle of the bearing
Remaining mainshaft
Olive up, place the gear puller under the large 1st gear. Note the rods on the gear puller have changed. The 3" puller is too small for 1st gear. Luckily I had these rods from the front suspension work I did.
Puller under 1st gear
Vintre is offline
post #26 of 133 (permalink) Old 03-19-2017, 02:38 AM Thread Starter
Vintre's Avatar
1st Gear Pull
Vintre is offline
post #27 of 133 (permalink) Old 03-19-2017, 02:42 AM Thread Starter
Vintre's Avatar
Olive up, place the gear puller under 2nd gear.
2nd Gear pull
2/1 syncro hub
Vintre is offline
post #28 of 133 (permalink) Old 03-19-2017, 02:46 AM
spydaman's Avatar
Thank you very much
Current cars 1975 spyder under resto, 1971 spyder needs work, 1972 GTjunior fully restored, 1 complete rolling shell spyder.exit 1989 75 T/S sold
spydaman is offline
post #29 of 133 (permalink) Old 03-19-2017, 02:52 AM Thread Starter
Vintre's Avatar
2/1 syncro ring
2nd gear
To remove 3rd gear, place in bench vise to remove small snap ring
Vintre is offline
post #30 of 133 (permalink) Old 03-19-2017, 02:55 AM Thread Starter
Vintre's Avatar
Input shaft up, place the gear puller under 3rd gear.
3rd gear pull
4/3 syncro hub and 3rd gear
Vintre is offline
Replace with
