1988 Graduate - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 2 Post By AngloSpider
post #1 of 5 (permalink) Old 03-16-2017, 07:34 AM Thread Starter
1988 Graduate
I had a dim headlight, changed the sealed beams and still have a dim headlight. Thoughts as to why?
DougPeetz is offline
post #2 of 5 (permalink) Old 03-16-2017, 08:30 AM
Check the ground wire it the headlights. The most common problem with the car is faulty grounds.
88 graduate
Since 2009
Disnyguy is offline
post #3 of 5 (permalink) Old 03-16-2017, 08:31 AM
Check the connection for corrosion or loose contacts.
Is the battery fully charged? Is the Alternator putting out enough voltage to keep things running with the proper voltage?
Louis718 is offline
post #4 of 5 (permalink) Old 03-16-2017, 10:53 AM
spiderserie4's Avatar
only one dim light?
that sure points to bad ground, as Disneyguy says! Each light has its own ground. It is a silly little ground wire between one of the screws that secures the headlight 'bowl' on to the car's body.
spiderserie4 is offline
post #5 of 5 (permalink) Old 03-16-2017, 11:04 AM
AngloSpider's Avatar
+1 for dodgy ground. Its this screw. I changed mine to run a wire through the screw hole and connected to the ground inside the fender:
alfabeach and spiderserie4 like this.
Spider S4 1990 manual red LHD
Spider 916 V6 2002 Silver
AngloSpider is offline
Replace with
