Coil wiring question - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 03-15-2017, 06:39 PM Thread Starter
'74 Spider. Please take a look at the pics and tell me your thoughts on the wiring. Car idles at around 4000 rpm. I'm wondering if the coil wiring is causing the problem.
Joe G
74 Spider.
Alfa1277 is offline
post #2 of 5 (permalink) Old 03-15-2017, 08:29 PM
Alfajay's Avatar
I can't make heads nor tails of your wiring from those photos, but it's hard to imagine how incorrect coil wiring would allow your engine to run OK, but with an incorrect idle speed.
What leads you to suspect the coil wiring? Is the car still Spica? When did you last lubricate your advance weights?
'63 Guilia spider
Alfajay is online now
post #3 of 5 (permalink) Old 03-15-2017, 08:46 PM
I'm with Jay, I can't see what's going on. But the coil would not determine idle. Did you check the timing? Did you check the throttle cable?
gprocket is offline
post #4 of 5 (permalink) Old 03-16-2017, 04:57 AM Thread Starter
Thanks for replies. I'm a novice, so I apologize for my ignorance. I checked timing, throttle and am at a loss for what's going on. Car was switched to carbs - they seem to check out ok. The wiring to the coil looked to be different than the wiring diagram, so I thought I would ask. I removed the carbs and am taking to a shop to make sure there's no issues with them. I removed the throttle cable and still had the high idle.
Alfa1277 is offline
post #5 of 5 (permalink) Old 03-16-2017, 07:39 AM
Alfajay's Avatar
Originally Posted by Alfa1277 View Post
Car was switched to carbs - they seem to check out ok. .... I removed the carbs and am taking to a shop to make sure there's no issues with them.
OK, I think we are homing in on the answer here.
My guess is that your carbs are fine, but they are not properly adjusted. So taking them off and showing them to a pro won't tell you anything. A better idea is to take the whole car to someone who knows how to synchronize and tune Weber carbs.
What exactly do you mean by "check out ok"? That the car runs well at speed? Webers will tolerate a lot of mis-adjustment, and still perform OK at highway speeds. It's getting them to idle that requires more precise tuning.
Who did the carburetor conversion?
'63 Guilia spider
Replace with
