1988 Graduate Speedometer and Tachometer problems - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 03-15-2017, 05:50 PM Thread Starter
Hey again, I know this has been posted here and there but I need someone to help put it in easy text for me. All of the gauges in my cluster work fine except the tachometer and Speedometer. What should I look at in order to hopefully fix this?
reesebre82 is offline
post #2 of 5 (permalink) Old 03-16-2017, 10:22 AM
miami592's Avatar
Try the fuse for the back up lights. I don't recall right off the bat which # but if it is out the Speedo/Tach can go DOA.
Jeff
1989 Graduate S3
miami592 is offline
post #3 of 5 (permalink) Old 03-16-2017, 12:06 PM Thread Starter
No luck, any other ideas?
post #4 of 5 (permalink) Old 03-16-2017, 01:06 PM
Using the electrical schematic and a voltmeter, check for 12 volts at the appropriate terminals.
85 GTV6 3L
alfaparticle is offline
post #5 of 5 (permalink) Old 03-17-2017, 03:32 PM
I had the same problem with my 87. Fuse #7 work the speedometer, tach, cigarette lighter, backup lights. In my case the lighter was shorted out, blowing the fuse. Fixing the lighter and replacing the fuse solved the problem
hosob is offline
