S3 spider hard start - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 3 Post By bayalfagtv6
post #1 of 11 (permalink) Old 03-15-2017, 01:07 PM Thread Starter
Hi all,
I have a 1985 spider graduate which now has a hard start problem.when the car is cold it always starts on the first crank. After the car has warmed up and been shut off and sits for a 10 or 15 minutes it takes quite a few attempts to start it, quite a bit of cranking. If it sits for a longer period it will start right up, probably because it has cooles down.once started the car runs excellent, good power, very smooth idle. I have been thru Greg Gordon's trouble shooting guide at his web site and all sensors check good. I recently had the injectors flow checks done and new pressure regulator installed, problem is still there. Plugs look good, light gray deposit. New fuel filter and gas line checked, no air leaks.
It's coming due soon for a California smog check, the last time it had one it barely passed after 2 fails and a new catalytic converter. I'm stumped, I'm starting to think L Jetronic ECU. One other odd circumstance, when it goes to the hard start syndrome, when turning the key to the start position, it does not seem to be giving me spark, once the key is released to the run position it will fire.
Any help is appreciated, the car has 140,000 miles but had a major rebuild about 15 years ago. I'm pretty positive compression is good.
bayalfagtv6 is offline
post #2 of 11 (permalink) Old 03-15-2017, 06:41 PM
ghnl's Avatar
Connect a voltmeter to the battery. With everything off, a fully charged battery should show 12.6V. 12.3V is ~ 1/2 charged.
Next see what it reads during cranking. Voltage must remain above ~ 10.5V for the computers to power up. It can sound like it is cranking over fine but if the battery is a little weak or an electrical connection is iffy then system voltage can drop below the computer's threshold. Perhaps when it is hot the starter is drawing just a little more power?
If it fails the cranking voltage test, disconnect the battery, clean all the battery to starter connections and have the battery charged. Make sure that the ground connections are clean & tight, too.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
- fuel injector cleaning
ghnl is online now
post #3 of 11 (permalink) Old 03-16-2017, 04:11 PM Thread Starter
Thanks ghnl, that seems to have done the trick, new battery and no starting problems. My next concern is the CA smog check. Any advice besides an Italian tune up?
post #4 of 11 (permalink) Old 03-16-2017, 04:32 PM
rogerspeed's Avatar
an s-3 like yours should pass smog ez with a new converter, so have had the valve clearances checked stone cold?
current:
83 Spider Veloce
ex:
rogerspeed is offline
post #5 of 11 (permalink) Old 03-16-2017, 06:19 PM
ghnl's Avatar
How old is the O2 sensor? They don't last forever, 60,000 miles is a good change interval.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #6 of 11 (permalink) Old 03-16-2017, 06:25 PM Thread Starter
I'll check the valves and timing marks while I'm in there, 02 sensor isn't that old, but I may change anyway. I still very rarely get a slight hesitation when shifting gears, usually after a hill climb or flat out pedal to the metal, seems rich. Is there some way to lean it out a bit?
post #7 of 11 (permalink) Old 03-17-2017, 09:05 AM
John533i's Avatar
I had the same problems as in your original post. The usual sensors ohmed out well, so I started replacing fuel injection parts, starting with my rotting hoses and ending with new pumps and reman'd fuel injectors. Everything pointed towards the TTS, and finally I bit the bullet and bought one from Vick's Auto, which is really a Fiat part, and my warm/hot start went away, along with some other issues that had cropped up. It was the TTS the whole time, even though it tested OK.
I'm going to try to get ahold of a known good proper TTS, as it seems to run rich at times, like yours. You can't see it on the spark plugs, though, which is weird.
86 spider Veloce
74 TR6
John533i is offline
post #8 of 11 (permalink) Old 03-17-2017, 02:30 PM Thread Starter
Thanks John533i, mine is the original and I may change it. I'm still stumped cause something just isn't quite right. If you can find a good price on one let me know. They're kinda pricey.
post #9 of 11 (permalink) Old 03-17-2017, 03:09 PM
spiderserie4's Avatar
"when the car is cold it always starts on the first crank."
I'd have thought with a bad TTS, you'd have real hard cold starts, because a bad TTS and you get no CSI squirting.
....no?
spiderserie4 is offline
post #10 of 11 (permalink) Old 03-17-2017, 04:32 PM Thread Starter
Good point spiderserie4, so will the csi squirt even when the car is warmed up? I have removed it on a warm engine and it does not squirt. Is this a sign the TTS is functioning properly?
post #11 of 11 (permalink) Old 04-04-2017, 12:06 PM Thread Starter
I guess I don't have to worry about CA smog check, took it yesterday and passed with flying colors. I changed tho 02 sensor before the check. Emissions were way below average and it's running fantastic.
ghnl, spiderserie4 and John533i like this.
Replace with
