Duetto Fuel Pump Loose Hose Barb - Page 2 - Alfa Romeo Bulletin Board & Forums
 6Likes
post #16 of 27 (permalink) Old 02-26-2017, 11:42 AM
IRONBLOCK's Avatar
I had this issue with the original fuel filter housing on my Duetto about 4 years ago. The nipple was just leaking and did not fall out. I don't know it the nipple is 'swedged' into the housing or 'cast' into it but I believe it was swedged and wonder if ethanol dissolved a sealant causing it to leak.
I like Gordon's solution; tried to fix mine with a torch and that did not work (housing melted). A used replacement is a good option.
My car has an aftermarket electric fuel pump and that nipple now has the same issue....
Mark
IRONBLOCK is offline
post #17 of 27 (permalink) Old 02-26-2017, 12:59 PM
101/105guy's Avatar
Originally Posted by papajam View Post
So, if I offer advice/experience on how to repair something, it means I'm trying to sell something?
Thought not!
No, I've never known you to do this !! ;^)
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is online now
post #18 of 27 (permalink) Old 02-26-2017, 02:02 PM
Trained (ex)Professional
papajam's Avatar
You know exactly what I mean and exactly what you are doing.
Careful. You're on VERY thin ice with some of your comments.
sbadaro likes this.
papajam is offline
post #19 of 27 (permalink) Old 02-27-2017, 11:35 PM
sbadaro's Avatar
Hope 101/105guy allows it... here goes... hope to refit clamp and test drive as soon as weather clears.
Sent from my GT-I9500 using Tapatalk
sbadaro is offline
post #20 of 27 (permalink) Old 02-28-2017, 08:16 AM
101/105guy's Avatar
It's OK by me !!
Nice photos!!
'64 Guilia Spider
'67 GTV
'68 Giulia Super
post #21 of 27 (permalink) Old 02-28-2017, 09:09 AM
Alfajay's Avatar
Yes, but what did you end up doing to secure the barb in the housing?
'63 Guilia spider
Alfajay is online now
post #22 of 27 (permalink) Old 03-05-2017, 07:54 AM
oldcanuck's Avatar
Mark
Had the exact same issue with my FISPA fuel filter housing on my Duetto and used JB Weld to seal/reset the barb. Been almost year now that this was done without additional issue.
Bob
1966 Duetto
1976 Spider Veloce
oldcanuck is offline
post #23 of 27 (permalink) Old 03-05-2017, 10:04 AM
Dr.G's Avatar
JB Weld is terrific stuff. I have the same issue on a FISPA fitting where it leaks between the casting and fitting. I found an earlier version that has a screw in barb fitting. No leaks. I did have Gordon's thought to thread the fitting but lack the machining ability.
Dr.G is offline
post #24 of 27 (permalink) Old 03-08-2017, 04:41 AM
sbadaro's Avatar
Update, fixed the hose back in place and as suspected, the pump kept squirting the gas out (busted diaphram...).
Spent the better part of last week looking for fuel pump, gave up on exact 4033 match, but got a hold of a couple of new FISPA 4059... not sure if the rod will 'sit' properly though... from the photos it looks like the FISPA 4033 will be tilted some 10mm inwards, whereas the 4059 ones I bought seem to sit flush along the edge... thoughts anyone???
sbadaro is offline
post #25 of 27 (permalink) Old 03-10-2017, 04:40 AM
sbadaro's Avatar
The only 'deep throat' I could find locally... used and abused... not good... diaphram has a life expectancy of 15 - 17 years and the silicon gasket spread on this thing looks like left overs from the cuban missile crisis...
sbadaro is offline
post #26 of 27 (permalink) Old 03-11-2017, 03:19 PM Thread Starter
Got my rebuilt pump back today from Then and Now Automotive. They tapped and threaded in a new hose barb where the original had come out, fitted a new ethanol-resistant diaphram, and replaced miscellaneous other pieces. Sent it off on Tuesday and got it back on Saturday, along with 2 gaskets, one for between the pump and the spacer and the other for between the spacer and the engine. Pics below.
Sbadaro - you might want to contact them about a rebuild kit for your pump.
sbadaro likes this.
BillD is offline
post #27 of 27 (permalink) Old 03-14-2017, 11:41 PM
sbadaro's Avatar
Glad things worked out for you. The new unused Fispa 4059 with the cam flysh to the surface threw out the spring in protest and I didn't want to shorten the rod nor did I have a wider spacer to tinker with, so I ended up putting the used replacement pump pictured above... it works... not sure for how long...
I'll fight going to electric pump as long as I can and will try replacing diaphram from the broken 4059 on the old original pump... look for 'jp weld' or locktight something to put it back together without leaks... original parts becoming more precious by the minute...
sbadaro is offline
Replace with
