Sump. How Low = Too Low ? - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 04-15-2004, 03:44 AM Thread Starter
beatle_bayly's Avatar
My Duetto's front end seems way too low, and the springs are certainly so stiff that the rear seems to pivot about the front. The car sits on 185/65/14" tyres.
My main concern though is sump clearance. As you can see I can't squeeze my flat hand under the sump. It's less than 3" off the road, with the sump-to-block join almost exactly 4" off the tarmac.
What clearance do other Spider owners have ? What is factory standard for a Duetto ?
Also, I'd appreciate an idea of the clearance between a sump and sump-guard. I can manufacture a sump-guard myself but I need to know basic dimensions.
Beatle
'85 Alfa 90 NSW Oztraya
beatle_bayly is offline
post #2 of 6 (permalink) Old 04-15-2004, 03:48 AM
164QV's Avatar
Hey Beatle! - you used to own a Dolly - so did I! although not a Sprint.
Anyways, that sump sure looks very low. I'll have to look at my own to measure how low it sits - but I'm sure its more than an inch higher. As to the sumpguard, I would buy a new one if I were you. They arent that expensive.
Theres one right here.
Jørgen
1969 1300GT Junior
1971 2000 Spider (racecar!)
1964 Vespa Gran Sport
164QV is offline
post #3 of 6 (permalink) Old 04-16-2004, 06:41 AM
Peter's Avatar
just went out and checked. My Duetto has 195/60/15 tires, and the sump sits about 5" above the tarmac. The sump guard sits about 4" above the ground.
Hope this helps
Peter
Currently: '65 Giulia TI
Previously:
'91 Alfa 75/'95 Alfa 164/'79 Alfa Spider '69 Euro 1750 GTV, '67 Duetto, '84 Spider Veloce
Peter is offline
post #4 of 6 (permalink) Old 04-16-2004, 07:54 AM
ar1750gtv's Avatar
Hope this helps
My GTV sits just about the same on 195/60/14 tires. I have recently installed new Centerline springs and Koni shocks and had to shim the front with 11 mm shims to gain an extra inch as I was hitting the sump guard on almost every bump.
'69 1750 GTV
Cogito, ergo Alfa Romeo
ar1750gtv is offline
post #5 of 6 (permalink) Old 04-16-2004, 08:09 AM
Roadtrip's Avatar
Location: Rapid City SD, Black Hills of South Dakota, Queens NY
74 stock spider, original springs, 185/60-14's, 4 1/2" clearance
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #6 of 6 (permalink) Old 04-16-2004, 07:41 PM
jclark's Avatar
Perhaps a look at motor mounts, or other rubber parts that suspend the motor/transmission...
jeff
jclark is offline
Replace with
