Oil level question.... - Alfa Romeo Bulletin Board & Forums
 6Likes
post #1 of 18 (permalink) Old 05-21-2016, 07:54 AM Thread Starter
...I feel like a dufus admitting this, but for 27 years now, I thought like most cars, the amount of oil between the two holes on the dipstick was ONE quart, not two.
Yesterday, I refilled the sump and filter after letting it drain for about a month, it was about as dry as a proper martini or a 72 year old virgin, refilled with 7 qts. of the proper 20w/50, let it run, settle...and the mark on the dipstick is between the two holes.
What gives? Does it mean it's down a quart? That it's in the "Acceptable" range? That the stick isn't accurately reading the sump level?
'89 Spider Quad, "Rosa", original owner..still in love all these years...
grazie is offline
post #2 of 18 (permalink) Old 05-22-2016, 07:07 AM Thread Starter
I guess no one changes their oil, thanks guys.
Bye.
grazie is offline
post #3 of 18 (permalink) Old 05-22-2016, 07:14 AM
not2old4toys's Avatar
Can't speak for your Alfa, but my 67 the crosshatch area is 2 quarts.
Depending on the size filter it could be 71/2 to 8. If the dipstick is not seated that will give a low reading too.
Cheers, Jon
Present:
1967 Spider
1974 GTV (1969 Tribute)
1967 Spider (project)
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is offline
post #4 of 18 (permalink) Old 05-22-2016, 07:56 AM
kcabpilot's Avatar
Don't feel like a dufus, I thought the same thing and for me it's been 36 years - lol
Basically if the level is between the two marks you're good and there's really no reason to keep it "topped off" you don't want it below the lower mark or above the upper mark.
Paul - 1972 Spider - (2)1991 164S's - 1983 308 - 2001 Discovery - 1997 F350
kcabpilot is offline
post #5 of 18 (permalink) Old 05-22-2016, 11:12 AM
IRONBLOCK's Avatar
Definitely two quarts between the low mark and the full marks on the dipstick (7.5 to 8 quarts)...I've been told there may be a tendency to 'use' a little more oil if you fill the sump all the way to the full mark but there may be less chance of oil pump cavitation (sucking air into the pump) during competition racing with a lot of sharp turns -like on a track. Cavitation may be more of an issue with the older Alfa engines though.
Mark
IRONBLOCK is offline
post #6 of 18 (permalink) Old 03-16-2017, 08:28 PM
Mark
I just checked (again) the reprint of my 1974 Owner's Manual and can find no explanation of the marks on the dipstick other than Min and Max.
FYI Per Owner's Manual a full oil change including filter requires approximately 7.8 US quarts.
Did everyone determine this two quart span between the min and max marks by observation? Or is there some Alfa publication that states this quantity?
1974 Spider
Work gets in the way of my hobbies. Nothing takes just 5 minutes.
BobG is offline
post #7 of 18 (permalink) Old 03-16-2017, 10:19 PM
Del
Observation. I measured the oil level when I added qts of oil during oil/filter changes, and observed that, yes, 2 qts between marks. I sure don't remember anything else in any of my Alfas through the years.
Del
Seattle
previously owned since 1964:
Del is online now
post #8 of 18 (permalink) Old 03-17-2017, 08:39 AM
Alfa engines carry a lot of oil capacity. The capacity or dipstick shouldn't be compared to a Chivvy V8, or other everyday hauler.
maseratiguy likes this.
alfaloco
Lexington, KY USA
alfaloco is offline
post #9 of 18 (permalink) Old 03-17-2017, 09:03 AM
Here's the full set of information from the oil specification on page 24 of my 1974 Owner's Manual for USA cars:
Engine * when full abt 7.1 qts
Engine danger level abt 4.75 qts
* This quantity is that needed for regular changing. The total amount of oil in the circuit (pan, filter, and passages) is about 7.8 qts.
Alfa thus claimed that the stock oil filter contained about 0.7 quarts.
If one takes those full and danger level quantities as corresponding to the MAX and MIN marks on the dipstick, the difference is 2.35 quarts. Rounding yields 2, but 0.35 is a nontrivial fudge factor.
1974 Spider
BobG is offline
post #10 of 18 (permalink) Old 03-17-2017, 10:02 AM
Gordon Raymond's Avatar
It's more fun in Liters...
maseratiguy and nunki like this.
Gordon Raymond
Now:
Gordon Raymond is online now
post #11 of 18 (permalink) Old 03-17-2017, 12:45 PM
Del
"but 0.35 is a nontrivial fudge factor"
Not terribly important to watch the level that closely. For two decades, since my 91S uses oil, I usually just kept it somewhere between the full and low marks, and it doesn't make any difference, except that it seems to consume oil at a slower rate if starting out at the mid level, ie, one qt low, than if I fill it to full, the problem evidently bad oil rings from new, and the oil level being higher if full.
The enormous oil capacity of the typical Alfa engine as compared to many other marques has always been an Alfa/Italian thing, supposedly for cooling IMO.
alfaloco likes this.
Del
Seattle
Del is online now
post #12 of 18 (permalink) Old 03-17-2017, 01:28 PM
IRONBLOCK's Avatar
Grazie,
Since we are making confessions and admitting to being dufus'; this should make you feel better.
My 164-S since new has burned about 1 quart of oil per thousand miles and I just accept that as a fact. A friend once told me that their 164 would burn oil till it reached the half way point between full and low marks on the dipstick. Then supposedly, it stopped burning oil or slowed down significantly.
I was in the process of "testing their theory" and not topping the engine oil up every other fill up or so when one day I went to Chik-fil A, for lunch. When I got ready to leave I put key in ignition and turned it like usual but the engine did not budge! It seemed like it was locked up and it was. My first thoughts were not pleasant but then I added a couple of quarts of oil and it started right up and ran just like normal. Apparently the low oil level sensor on the engine is still working! I didn't even know there was one...
Mark
alfaloco and Gordon Raymond like this.
post #13 of 18 (permalink) Old 03-17-2017, 03:16 PM
Del
There is a sensor and light for low oil level, but I think that is all it is (haven't bothered to check the wiring diagrams) as the car does run when it doesn't work or the red light comes on. Both the one in the 164S and the Milano crapped out years ago. I tricked the one in the 91S with a resister to put the light out, but that didn't work for the Milano, so I just put tape over the always on light, the car running fine with the sensor unplugged or not. The 91S ran fine with the light on due to a failed sensor.
I wish my 91S got ONLY 1k miles to a quart, lol. Try less than half that, for fun. It's been the same for all the 23 years I've owned it, and I assume it was that way from new. Has never changed, and the car leaks no oil, either sitting or running.
"Then supposedly, it stopped burning oil or slowed down significantly"
Kind seems to be the pattern, oil consumption slowing a little (but certainly not stopping), the oil level not as close to the bad oil rings?
Del
Seattle
Del is online now
post #14 of 18 (permalink) Old 03-17-2017, 03:24 PM
After draining my oil and changing the filter I added 5 quarts, started the motor and let it idle long enough to fill the new filter. I then pulled the dip stick and marked that level by making a light file cut on the dipstick. Added another quart and marked that level, added the seventh quart and marked that level. Now I know if the oil is low and exactly how much. By the way, mine uses the first quart within about 200 miles and then stays a quart low forever. It just doesn't seem to like all seven.
hosob is offline
post #15 of 18 (permalink) Old 03-17-2017, 05:39 PM
Del
Just leave it one qt low then. No sense wasting oil.
Did you let the oil drain back down for a while before measuring and marking? I found it takes a while.
Del
Seattle
Del is online now
Replace with
