The proper tool for round flat nuts on the Roundtail top frame - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 21 (permalink) Old 05-25-2016, 04:05 PM Thread Starter
USTA BE AN AD-MIN
ossodiseppia's Avatar
Wes, it took me several hours to get those trunnions out of three frame parts. It's indeed a nightmare. I'm glad you got them out and are on your way to a restored top frame.
ossodiseppia is online now
post #17 of 21 (permalink) Old 05-25-2016, 04:42 PM
Dr.G's Avatar
5/16-18 button head socket cap screw is readily available and I just re-threaded my 8mm hole to this size.
5/16 is just slightly larger than 8mm so it seems to work nicely. 5/8" long is probably the ticket. The 1/2" long 5/16-18 I bought is slightly too short.
Good luck.
Dr.G is offline
post #18 of 21 (permalink) Old 03-20-2017, 05:13 PM
Dr.G's Avatar
The amazon wrench broke on me at the pin. I wouldn't recommend it.
Dr.G is offline
post #19 of 21 (permalink) Old 03-20-2017, 05:16 PM Thread Starter
USTA BE AN AD-MIN
Wow. I'm really sorry, Wes. Which one did George buy? I seem to remember his looked user modified.
post #20 of 21 (permalink) Old 03-20-2017, 05:33 PM
Dr.G's Avatar
Going to make a socket or try the milled nose. The pin is too fragile for frozen flat nuts. Oh well.
Dr.G is offline
post #21 of 21 (permalink) Old 03-20-2017, 05:53 PM Thread Starter
USTA BE AN AD-MIN
Ah, you were loosening the nut. Use a MAP torch to heat them up. Quench with WD 40, repeat, repeat...
Replace with
