Battery Replacement - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 01-24-2006, 05:44 PM Thread Starter
Battery Replacement
Need a new battery for my '88 Spider, what should I look for specifically?
FerrariJoe is offline
post #2 of 9 (permalink) Old 01-25-2006, 05:07 PM
alfabeach's Avatar
I think a good sealed battery like the Optima is the way to go. You have to remove the battery to the check fluid level (pita). Thats what I plan on using the next time and also use the side posts, because the top is to close to the fender. Richard
Richard
76 Alfetta GTV gone to rust haven, 89 Spider the red graduate, 86 GTV6 on wish list
alfabeach is offline
post #3 of 9 (permalink) Old 01-25-2006, 11:33 PM
John M's Avatar
I am sure someone will soon chime in and tell you about the odyssey battery.
I personally have a yellow top optima like Murray in my 92.
Best Regards,
John M
[SIZE="1"]1978 AR Spider Veloce 2000....the first and still here...Bianco
1984 AR Spider Veloce............the second & gone to the parts bin....Rosso
1992 AR Spider Veloce............the third and still here...Bianco
1991 AR 164L........................the fourth and traded on the SS....Rosso
1965 AR Sprint Speciale..........the fifth...in boxes....sold....Bianco
1978 AR Spider Veloce 2000....the sixth gone to be a parts car...slow black
1993 AR Spider Veloce...........the seventh, freshening up to be sold....Verde Inglese
1982 Ferrari 308 GTSi.............the first, fresh restore....Azzurro[/SIZE]
John M is offline
post #4 of 9 (permalink) Old 01-26-2006, 06:48 AM
alfapipes's Avatar
I like the OPTIMA's too. I have one in the Spider and the Milano. I trickle charge them over the winter, and they start the cars easily in the spring. Both of mine are red tops.
Russ
alfapipes is offline
post #5 of 9 (permalink) Old 01-26-2006, 06:58 AM
Craig LNU's Avatar
OPTIMA, per the recommendation of two Alfa mechanics, now sits in my Spider.
1994 Spider Veloce Ce #88 w/15K Miles (sold)
2006 Maserati GranSport Spyder w/5k miles
Craig LNU is offline
post #6 of 9 (permalink) Old 01-26-2006, 08:35 AM
sprintgtc's Avatar
I've switched all the Alfas to Optimas. Love them!
Mike Macaulay
Seattle
69 Spider
69 GTV
74 GTV
84 Spider Veloce
sprintgtc is offline
post #7 of 9 (permalink) Old 01-26-2006, 09:03 AM
WopJob's Avatar
Spider battery.
What ever you buy, make sure that:
1) the positive post is on the left side when both posts are FACING THE TRUNK. (just in case you need to jumpstart someone "
2) the more powerful the better for winter starting, if applicable to you.
WopJob is offline
post #8 of 9 (permalink) Old 01-26-2006, 01:43 PM
Don't buy a cheapie Autozone battery. Not enough power to run the ECU, ignition etc. I have an Interstate in my 88 spider. Works well.
Dolle Dolf is offline
post #9 of 9 (permalink) Old 01-26-2006, 02:03 PM
othercarsaford's Avatar
You knew it was coming...
I have an Odyssey Drycell in my Junior, and I'll never buy another after-market battery. No fluid, small, weighs 15 pounds and is supposed to last 11 years. Plenty of power to start my Junior even if it's sat for a month between starts.
othercarsaford is offline
Replace with
