87 Quad running like s**t - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 06-15-2012, 05:07 PM Thread Starter
Forzaguy's Avatar
The drama:
I just took my 87 quad back from a mechanic (ex mechanic now). Car has 97K miles on it. About 3 weeks ago I was on a tour with the AZ Alfa Club heading north towards Payson and on to the red rocks of Sedona with the Alfa running smooth and powerful. Suddenly just before Payson the car began to lose power and rolled to a stop, Car was still idling smoothly but it would lurch and sputter if you tried to give it gas and accelerate. Sweeper car behind me said he thought he saw bits being blown out the exhaust. Hmmmm, maybe a CatCon issue. Luckily I had upgraded my AAA and soon I was on a flatbed on my way back to Phoenix where I delivered it directly to the recently "new" mechanic. A few days later he called and said the catcon was plugged and needed replacement and I agreed. A few days later I took possession of the car AND it still ran like s**t. Basically the same symptoms. Now I was thinking "false air" and I discussed it with him. Told him to replace all the top side vacuum hoses and check all the connections on the intake hose from the air cleaner to the throttle body. He kept claiming he was really busy and it might take time to get back to the Alfa. Today I finally brought it home, still running like it did before, and he never replaced the vacuum hoses as we had discussed.
Am leaving town for a week travelling to a reunion of my OLD air force tech school class but will begin troubleshooting it when I get back. I have a new fuel pump and fuel filter I was going to install anyway so I will start with that and replacing the vacuum hoses under the hood. Could a bad TPS cause these symptoms? Any other suggestions eagerly accepted.
Forzaguy is offline
post #2 of 4 (permalink) Old 06-15-2012, 05:44 PM
Push hard and live
DPeterson3's Avatar
If the wire to the AFM disconnects, it produces what you describe. Perhaps the TPS or the AFM itself. Of course, check the main air-feed that connects the AFM with the intake plenum, and all other possible vacuum sources up there.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #3 of 4 (permalink) Old 06-15-2012, 05:52 PM
Gubi's Avatar
I'm betting you have a miss on a cylinder. Pull plug wires one at a time. If pulling one of them doesn't make a difference, there's your problem.
A bad miss will send unburned fuel directly into your cat. This ignites when it hits the cat and melts the matrix. If a cat melts, you always need to troubleshoot the problem BEFORE replacing the cat.
Based on the details of your post you probably want to find a new, new mechanic.
1991 Spider
Gubi is online now
post #4 of 4 (permalink) Old 06-15-2012, 05:56 PM
ghnl's Avatar
Agree with Don (and do not disagree with Tom...!). My first thought was a disconnected/loose AFM harness connection or disconnected/loose intake air duct. Look closely for splits in the accordian section of the intake air duct.
The catalytic converter may well have been bad but if that was the only issue replacing it would have solved the problem.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
- fuel injector cleaning
ghnl is offline
Replace with
