Head Gasket Replacement for Dummies Procedure - Page 8 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #106 of 113 (permalink) Old 09-05-2015, 11:04 AM
mflanary's Avatar
Can anyone tell me where I can get a new copper washer for the overheat warning sensor? Mine is leaking slightly.
Michael
1993 Spider Veloce
mflanary is offline
post #107 of 113 (permalink) Old 09-05-2015, 11:09 AM
Gordon Raymond's Avatar
Most NAPA auto stores have them. An aluminum washer will work too.
Gordon Raymond
Now:
Gordon Raymond is offline
post #108 of 113 (permalink) Old 09-05-2015, 11:35 AM
mflanary's Avatar
Thanks I'll check NAPA!
Michael
1993 Spider Veloce
mflanary is offline
post #109 of 113 (permalink) Old 07-01-2016, 08:58 AM
Engine rotation to find master link?
I'd like to thank everyone who has contributed to this thread!
I have the cam cover off and am ready to take out the master link from the timing chain, but I am unable to rotate the engine. I've tried using the fan and even the power steering pump, but the belts slip instead of turning the engine. I checked that the car is in neutral and have the spark plugs removed. What am I missing? I'd rather not use the started to rotate the engine, but I'm out of other ideas.
Also, I checked the compression prior to opening up the engine to see about needing a valve job in addition to the head gasket. My numbers were all 130 lbs. (128-131). Is this a valid test for a cold engine, and are these number indicative of reasonably good valves?
billj is offline
post #110 of 113 (permalink) Old 07-01-2016, 10:25 AM
Did you pull the spark plugs? Is is out of gear?
Gordon Raymond
Now:
post #111 of 113 (permalink) Old 07-01-2016, 10:53 AM
spiderserie4's Avatar
Originally Posted by billj View Post
I am unable to rotate the engine....I checked that the car is in neutral and have the spark plugs removed
put the car in 4th gear and push it forward (if it is not up against the garage wall!) otherwise maybe try getting a big socket and breaker bar onto the crank pulley.
With plugs out it should turn fairly easily.
Also, I checked the compression....My numbers were all 130 lbs. (128-131). Is this a valid test for a cold engine,?...
Compression needs to be done hot and 'WOT' (wide open throttle) to give a proper indication. Cold readings can be all over the shop.
spiderserie4 is offline
post #112 of 113 (permalink) Old 03-20-2017, 12:06 PM
sbadaro's Avatar
This string has my name all over it 😩... other than read carburator where it says injection, is there anything to be note for the same on 1975 nord engine???
Sent from my GT-I9500 using Tapatalk
sbadaro is offline
post #113 of 113 (permalink) Old 03-20-2017, 05:45 PM
gigem75's Avatar
I helped my cousin rebuild his Sunbeam Alpine in Memphis during the winter and when we tried to crank it the starter couldn't turn it over. New mains and rods and super cold oil was the problem. We solved it by towing and dropping the clutch in second gear. The motor fired up and ran for years thereafter. It just needed a little persuasion. If you are sure there are no mechanical bits inside the motor getting in the way you can try the tow and clutch dump. No warranties expressed or implied.
currently
74 GTV restored daily driver
71 Berlina in resto
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
gigem75 is offline
Replace with
