Head Gasket Replacement for Dummies Procedure - Page 2 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #16 of 113 (permalink) Old 11-15-2010, 07:34 PM Thread Starter
Vintre's Avatar
Oil buckets.
Install buckets into their original positions.
Install cams and oil cam shafts.
Install journals in their original positions. Tighten 13mm nuts, washer side down.
Align the cam shafts to the cam shaft timing marks at the front of the cams with the marks on the front journals.
Vintre is online now
post #17 of 113 (permalink) Old 11-15-2010, 07:42 PM Thread Starter
Vintre's Avatar
Place rag over opening to catch any small parts from falling in. Get chain in position to re attach.
Re attach chain using master link. Ensure that there is one metal tab in the center, one on the open end and then the clip. Again, note the orientation of the clip. Closed end towards the exhaust.
Place strong rod against chain tensioner. Loosen 14mm nut 1/4 turn and no more, to release tensioner. Tighten nut.
Re check cam shaft timing. All good here!
Instal new half moons (2) in the back of head. If you forget these, you will leak oil immediately from the back of the head and will have to remove cam shaft cover, gasket and intall.
post #18 of 113 (permalink) Old 11-15-2010, 07:50 PM Thread Starter
Vintre's Avatar
(2) half moons in position.
Install cam cover gasket. Install spark plugs.
Install cam cover nuts, using 4 new paper washers in the front, 2 re used metal washers in the rear, all in order and torqued according to the procedure.
The procedure. I think that Eric, ghnl, made this but I can't remember. Winner, winner, chicken dinner, it was Tifosi! Thank you.
Install (2) 10mm bolts at front of cam cover.
post #19 of 113 (permalink) Old 11-15-2010, 07:59 PM Thread Starter
Vintre's Avatar
Install over heat warning sensor using 27mm socket (thanks Tifosi). Re attach wire to top.
Install (2) 19mm bolts that hold the power steering pump.
Install VVT using allen key (3).
Install 13mm bolt through the fuel rail holder (under) to the air intake manifold.
Push the rail towards the engine, placing the injectors back into their place. Attach the (4) air intake runner hoses.
post #20 of 113 (permalink) Old 11-15-2010, 08:06 PM Thread Starter
Vintre's Avatar
Attach ground, 10mm bolt.
Attach fuel injector holders, 10mm bolt.
Install thermostat housing gasket.
Install thermostat housing (2) 13mm bolts.
Install and tighten clamp on antifreeze hose below thermostat housing.
post #21 of 113 (permalink) Old 11-15-2010, 08:06 PM
ghnl's Avatar
hmm, not that I remember either. Perhaps my evil twin Tifosi?
If I may add to this excellent post, when re-tensioning the chain ofttimes the spring is not strong enough to fully tension the chain. It might need a little nudge with the pry bar to make sure the chain is tensioned. You don't need to try to stretch the chain, just remove most of the slack.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
- fuel injector cleaning
ghnl is online now
post #22 of 113 (permalink) Old 11-15-2010, 08:12 PM Thread Starter
Vintre's Avatar
Install fuel injector connectors, in the correct position, and other connectors on this side.
Install hard and accordian air tubes that go across the top of the engine.
Install spark plugs wires, air filter, and air filter box.
Install oil dip stick tube, 10mm nut.
post #23 of 113 (permalink) Old 11-15-2010, 08:15 PM Thread Starter
Vintre's Avatar
Fill with new antifreeze through the overflow bottle. S4 self air bleeds, so run the engine a bit and fill as needed to the correct level.
That's it. It's a great, satisfying feeling.
Have some fun.
Vin
post #24 of 113 (permalink) Old 11-16-2010, 04:03 AM
jcslocum's Avatar
Excellent write up and pictures!!!
It should go without saying that the oil should be changed if you do the head gasket, The Anti-Freeze too.
Jon '74 GTV RIP Tifosi
jcslocum is offline
post #25 of 113 (permalink) Old 11-16-2010, 06:02 AM
65Sprint's Avatar
Excellent documentation and pictures. Thanks for posting.
Rich Hanning
65Sprint is offline
post #26 of 113 (permalink) Old 11-16-2010, 10:32 AM
neo297's Avatar
As I am going to do this very soon I thank you for your effort. This brings togeather everything that was in multiple other posts
Paul
'87 quad, '85 FJ1200,'86 FJ1200 '95 ford explorer, '00 V8 ford explorer, '04 yukon xl
neo297 is offline
post #27 of 113 (permalink) Old 11-16-2010, 10:59 AM
DDS
Member
Master Link
Vintre
I think your master link is installed incorrectly. The photo shows two plates on the front and the clip on the back. There should be one plate in front and one plate in the back all held in place with the clip.
The clip is not designed to carry any load just hold things in place. I would hate to see all of you work be for not, along with the new valves and other parts needed if the chain breaks.
DDS is offline
post #28 of 113 (permalink) Old 11-16-2010, 11:01 AM
Rustic's Avatar
That was a great write-up, especially with all of the pictures. Thank you!
Rustic is offline
post #29 of 113 (permalink) Old 11-16-2010, 11:15 AM
1966-2013
Tifosi's Avatar
I'm diggin' it, thanks for sharing.
Yes, I claim the cam cover tightening sequence graphic.
One small note of possible worth:
At times the VVT pluger that goes through the cam cover can be real easy to drop out/misplace/lose/forget during removal storage and reinstall.
If leaving it actually in place in the cover, a small slip of vacuum hose over the protruding exterior end pre-cover removal will prevent it going anywhere until you are done done.
'Course while things are apart it offers as good a time as any to replace the o-ring that seals that plunger from leaking oil down the front of the head.
Oh, the dunno what it is 27mm wrench fitting sensor at the top back of the head?
Overheat warning lamp as found on the monopod.
Not present in the dual pod engines.
Darren
as hosted by
Tifosi is offline
post #30 of 113 (permalink) Old 11-16-2010, 12:09 PM Thread Starter
Vintre's Avatar
I am glad that this thread will be helpful to others.
Tifosi, thanks for the cam cover bolt tightening sequence and letting me know about the over heat sensor (corrected above).
DDS, I am pretty sure I caught the master link but just in case, off I go to the garage to check.. If I did it correctly, I will post a correct picture, because I don't want anyone to follow something that is wrong.
Vin
Replace with
