Clutch pedal question - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 11-26-2009, 04:59 PM Thread Starter
AntonyR's Avatar
Sorry if this is obvious, but I took the pivot arm out to see what kind of shape its in, and took a look at the clutch pedal. Is this weld holding the pivot end to the pedal shaft supposed to be there? Just checking.
'67 Duetto (Rust In Peace), '87 Spider Quadrifoglio
AntonyR is offline
post #2 of 4 (permalink) Old 11-26-2009, 05:58 PM
ghnl's Avatar
Doesn't look like the clutch pedal in our '84 Spider.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
- fuel injector cleaning
ghnl is online now
post #3 of 4 (permalink) Old 11-26-2009, 06:03 PM Thread Starter
AntonyR's Avatar
It's out of an '87 Spider. Shouldn't it be the same? If mine looks different than yours, that worries me a bit... Can anyone else verify this?
AntonyR is offline
post #4 of 4 (permalink) Old 11-26-2009, 06:31 PM
ghnl's Avatar
I would assume it is the same. Note: I have not removed the clutch pedal. I did go out to the garage and look up under the dash with a flashlight. I slide my hand up the length of the pedal and did not feel anything that would indicate a welded joint.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
Replace with
