help! rear disc brake removal...
hi,
i've been trying to remove the rear driver side brake disc on the stock dunlop brake system on my '65 ti. i'm in the process of replacing the reverse treaded wheel studs into longer right hand ones. i have removed the two flat head screws that i thought were the only screws securing the disc to the axle but i obviously i'm wrong. i pulled the axle already, pounded the studs and removed the 2 flathead screws but how come the disc won't come out? do i need to have the wheel bearings taken out at a machine shop so i can just slide the disc out through the axle?
any help will be appreciated...thanks!
benji
Reason: add more info.
