carb swap
For sure I'd drive it awhile with the setup it has, assuming it works OK, and see what you think, before deciding whether to swap. Single-carb setups on relatively large engines can result in very smooth, torquey power (witness most classic American iron). And the carb setup is a breeze compared to Webers. The Webers will certainly snort and snuffle in an exhilerating way, and give better top end, but may not be better at the bottom end. Plus you'd be doing the setup for a pretty odd engine (nonstock approx. 1700 cc). I've driven a number of single-carb 1300 Giuliettas recently and was really impressed, compared to my dual-carb Super.
Also, the 5.12 with this larger engine will probably really wind out, assuming you can get the column shift to work adequately. The car ought to feel like a rocket, at least in off-the-mark acceleration.
Has anyone calculated what displacement you get on a 1600 stroke crank with 1750 pistons, which is what this car has?
Andrew Watry
