Old 02-19-2008, 09:44 AM
boxcarracer boxcarracer is offline
Giulia - Wood Dash Inserts
Hey guys
The color of my dad's wooden dash inserts are beginning to change color. They aren't warping or cracking, just becoming discolored (well actually... darker).
Does anyone sell precut inserts? I want this to stay as close to original as possible.
Thanks in advance
Pic for views
Old 02-19-2008, 11:21 AM
Jeff Trask Jeff Trask is offline
Try this: Centerline Products: DD505 Dash Wood Verneer Giulia Super
1970 Giulia Ti 2.0+
2007 Ford F-150 Super Crew
Old 02-19-2008, 11:28 AM
Andrew Andrew is offline
They bleach over time from the sun from dark to light. In addition Centerline's kit, you can make your own new veneers, which I've done a couple times. You have to take the dash out and completely apart to do it. They remove the wood, trace onto the veneer of your choice, cut, varnish, polish, etc, then reassemble. It's not a small job. But if you cut your own it's practically free, other than the minimal cost of the veneer.
Andrew
Old 02-19-2008, 12:09 PM
Yea I thought about cutting some veneer but I'd rather have something already cut to fit.
I'll send the link to my dad (thanks Jeff) but I won't rule out the DIY, it's up to him to decide.
Thanks guys
Old 02-19-2008, 12:18 PM
Either way you have to take the dash out and apart to replace the veneer.
Andrew
Old 02-19-2008, 12:39 PM
Yea that's not a problem
The dash is already off the car at the moment, my dad had to for other reasons (radio change and cluster lights)
Old 02-20-2008, 09:34 AM
JOEBMW's Avatar
JOEBMW JOEBMW is offline
What about refinishing the orginal wood?
Old 02-20-2008, 09:53 AM
Can a veneer really get refinished?
If so... do you have any products to recommend? At this point it's worth a shot.
Old 02-20-2008, 10:11 AM
JOEBMW's Avatar
i dont see why not. i have not done it but i will attempt it in the next few weeks. i have the same problem as you...my giulia wood dash is discolored along with the dash itself.
This is what i would do...
Light sand with a fine grit sandpaper. Wipe clean with prep-surface cleaner.
Use either a sponge brush or a regular fine brush to apply either a Min-Wax stain/poly mix or stain then poly mix. (Stain/ploy mix is a single stage mix with color and clear mixed together, cuts down time and material needed)
Once all that is done i would let it fully dry. If there are any inperfections i would lightly scuff it then apply another coat. This should work
Old 02-20-2008, 05:05 PM
gprocket's Avatar
gprocket gprocket is online now
Theoretically you could refinish the veneer but be very, very careful. First the finish is a thick material that was to have a glass like surface with no grain lines. You will likely need a chemical stripper to lift it off but not allow it to soak into the back side of the veneer. Strippers usually use water to neutralize the solution - DON'T use water - your veneer will surely curl up. Once the finish is removed you are going to need to carefully sand or steel wool the surface (I really hesitate to say steel wool - very difficult to control). You need to get rid of the finish that has been in bedded in the grain but the veneer is so thin to begin with that this is virtually impossible to do. Any remaining finish will not accept stain and the result will be a blotchy finish. Sand too much and it's game over.
Also, although the wood on the dash proper is relatively stout (it is actually a multiple ply), the veneer for the curved console (of a Berlina anyway) is glued to a thin masonite type paper substrate. It is usually warped or cupped from moisture and with all the cutouts is very fragile.
For all the work, you are much better off starting with fresh veneer that is pre-sanded and has the proper backing that won't allow the glue to saturate the wood. All the dashes I've seen are standard marine grade straight grain red Mahogany (at least it is easily available in the states). Apply a stain and a polyurethane (UV stabilized) or lacquer finish and you will be much happier with the result. If you don't want to do it yourself, look for a guitar repair shop - they could easily handle it.
Good luck!
- Rich D.
I like Alfas
Old 02-20-2008, 08:20 PM
Damo105's Avatar
Damo105 Damo105 is offline
Andrew
Andrew, which veneer did you use? My carpenter brother is going to make me replacement veneers, but he wants to know which mahogany veneer to use, as apparently there are lots of different types of mahogany veneer.
Damien
'74 GTV 2000 - [COLOR="Blue"]LeMans Blue [/COLOR]
'70 1750 Berlina - Biancospino. Project street and occassional track car
'74 2000 Berlina - parts car
'99 Seat Cordoba - [COLOR="Gray"]daily driver[/COLOR]
'95 Peugeot 306 S16 - gone, but not forgotten
Old 02-20-2008, 10:02 PM
I used pre finished teak on my 1967 Super and it looked great!:
1970 Giulia Ti 2.0+
Old 02-21-2008, 12:11 AM
super1750's Avatar
super1750 super1750 is offline
Available in Germany
Hi Guys,
I believe the inserts are available from Alfa Service Hurtienne in Germany.
Alfa-Service ::: Home
Choose shop, choose country, enter as visitor, choose car, choose Body parts, choose Interior, choose wood cover... done!
I have tried to refinish the inserts before and it was not possible. The veneer isn't varnished, but laminated with a soft rubber-like material that can't be sanded off or otherwise removed to leave a surface that can be refinished.
Jeff, your inserts in the super look super authentic...
regards
Bob
95 145 1.7l-16v boxer, 71 Giulia 1300 Super (2.0) ;-) (86 Vespa PK50XL)
  #14 (permalink)
Old 02-21-2008, 07:48 AM
I bought some kind of mahogany at MacBeath Hardwoods. It wasn't actually that close a match, but it was what I wanted at the time. This was over 20 years ago now, so my recollection is less than 100%.
Andrew
  #15 (permalink)
Old 02-21-2008, 07:55 AM
rogerspeed's Avatar
rogerspeed rogerspeed is offline
Refinish by stripping with chemical stripper such as spray citrus strip available at ACE hardware. You spray the stuff on like shaving creme, let it sit for a few hours, the squeegee off and wipe. Now you have the factory surface before they lacquered. so don't sand here, just stain. There has been much disagreement about the proper shade, my take is a red mahogony, look under the edges wrapped by the metal trim, the blonde color is the result of fading. Stain, wipe then lacquer/varnish, sanding between coats, done for many cars.
67 BMW 1600ti/Alpina
74 Spider project
69 BMW '02 SR
www.machocheese.com
"just say no to reductionism"
