10-13-2009, 05:14 PM
Hi Dave,
Yea, the front is a little low, plus the rear of the car is sprung to have my kids (ballast!) in the back seat. I have the sneaky feeling that I will be adding some spacers to the front to get it a little higher (but not USA spec height!) as well as fiddle with the sway bars and poly bushings (+/-). Any suggestions?
Thanks!
Peter
10-13-2009, 05:19 PM
The Berlina Front End
Hi Dave,
One last thing I forgot to mention, the front end has the adjustable upper a-arms. When the shop did the alignment after I did the rebuild, they weighted the car down to mimic the actual ride height before they did the alignment. So the geometry is not really stock, but still, I think your ride height point is well taken. Thanks again.
Peter
10-13-2009, 06:48 PM
Hi Peter, are you using 1750 lights on a 2 litre grill ? Looks really good.
10-13-2009, 07:44 PM
Hello Hans-Peter,
Actually what I did was buy a '71 front clip from APE, drilled out the spot welds for the two headlight sheet metal brackets, then riveted these into my '72. The fog lights sit just where they should, the outer hi/lo beams sit in the correct location, and adjustments to both are stock (well, '68 stock at least!). The next trick was figuring out a grill. I like the larger '72 triangular portion, so I created a new single bar to connect the fog to the center triangular grill. Again, all looks to the naked eye like this is how the car left the factory, which is my intent with any modification I make to an Alfa.
Sincerely,
Peter
10-13-2009, 08:31 PM
Well I think your front looks better than either factory setup, I might try a 2 Litre sheild on my 1750.
11-03-2009, 11:28 AM
SoCal Bianca
unmolested
'67 Giulia Super
'99 Ducati M900
11-03-2009, 12:06 PM
Lots better than my old track day Giulia Ti
11-03-2009, 12:16 PM
And being a hooligan at Donington Park
11-03-2009, 12:26 PM
Another shot
11-19-2009, 09:37 PM
I had the Super out for a drive last Sunday and managed to catch some afternoon light.
11-19-2009, 09:48 PM
Sweet !!
Just something about the look of an Amaranto Super ;^)
Very elegant !
Still running the 1300 or have you had a chance to put in the BIG motor ?
Randy
'65 Guilia Spider
'67 GTV
'67 Duetto-in progress
'68 Giulia Super
'70 Giulia 1600 'S'
11-19-2009, 10:18 PM
I'm still running the 1300, Randy. Last summer it got a new head gasket and Roland sent me a good set of Webers to replace the Solexes. A good running Alfa is such a delight to drive.
With the 5.12 rear end, the little 1.3 motor isn't a sluggard at all and can easily keep up with modern traffic. You just have to get used to running at
4k rpm to get anywhere.
A couple of friends helped me pull the engine out of the Alfetta a couple of weekends ago. I'm planning on building it but I'm not in a great hurry. A more pressing need is new rear suspension bushings which really need to be replaced. 2nd gear synchro is bad, something I knew about when I bought the car, but I have an almost new close ratio gearbox that will work well with the 5:12 gears. With that long first gear it'll be a blast to drive.
It was fun shooting the photos. The little car positively glowed in the afternoon light. Of course everywhere I park it people ask what it it is. Supers are real celebrities.
Thanks to Roland/Giulia Blanca's help and the advice of fellow BBers (including you, of course) I found a car I can enjoy for years to come.
Yesterday, 08:25 AM
Wow, very beautifull Amaranto Supers!
Here is mine:
Giulia Super 28th February 1969
Yesterday, 10:07 AM
Here is mine:
I just might be sold on Amaranto being THE color which best shows off the lines of our cars.
1966 Giulia Super (current)
1966 Giulia Super (R.I.P.)
1967 GTV (R.I.P.)
1955 1900CSS (R.I.P.)
Yesterday, 11:50 AM
Il Vecchio, what wheels do you have on your car, GTA replicas?
Any sideways pics...............
Dave
