Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Sedan (1963-1974)
Old 11-14-2007, 07:20 PM
Richard2 Richard2 is offline
'69 windshield in a '73
Will a 1969 Berlina glue in windshield fit in a 1973 Berlina? Did they offer glue in windshield in 1969? Will a gasket windshield fit in a 1973 Berlina? If there is a choice which do people prefer glue in or gasket?
Richard2
1991 164B Silver Daily Driver
Old 11-14-2007, 07:41 PM
rogerspeed's Avatar
rogerspeed rogerspeed is offline
All the windshields are basically interchangable in the 105/115 sedans. So you can either glue-in a gliue-in winsheild or install a gasket windsheild with the gasket. The gasket windsheild should also have an aluminum locking/trim strip which is a different piece(s) than the trim for the glue-in windsheild. I have seen two slightly different sizes of the glue-in, both work. When installing the glue-in you need to trim the windsheild surround on the interior side with windlace, sometimes called snap trim. In any event when you remove the old windsheild be ready to do bodywork arround the opening, as there will be some corrosion. As to which is better, the gasket type is easier to remove and reinstall. The glue-in type may seal better initially if enough sealant is used, but is a tricky install, the factory glue-ins suffer from the glue/sealant drying out and leaking leading to the corrosion. The gasket type, to seal propperly requires a smooth, well finished opening.
PS you can install the gasket type without the trim, but it won't look right.
'67 BMW 1600ti/Alpina
And Looking For Another
www.resoles.com
"just say no to reductionism"
Old 11-16-2007, 09:00 AM
George Willet George Willet is offline
Senior member
And Richard, I have the windshield, gasket, and the trim here in Anacortes, only 45 minutes from you. Bring $125.00 and your problem is solved.
George Willet
willet@q.com 520-374-2220: please do not use PM, email me direct, saves us both time.
Note: I prefer to offer parts to the AlfaBB members first, and eBay second.
THESE are the good old days!
There are no easy answers to complex problems.
