Old 06-13-2007, 08:40 PM
James1750's Avatar
James1750 James1750 is offline
CWP Offset - 10/43 - workshop manual (diff)
Hi There -
just wondered if anyone has details pertaining to berlina 10/43 2litre limited slip diffs....
I'm after the hypoid offset for the crown and pinion wheel (see below image for example of hypoid offset)...
Is this contained within anyones workshop manual?
James
1968 series 1 1750 GTV (RHD)
Old 06-16-2007, 03:50 PM
Andrew Andrew is offline
I'm just looked in my factory diff manual and I don't see that it covers it. It might be contained in the factory engineering/technical characteristics pamphlet for the Berlina, if you can find one.
Andrew
Old 06-17-2007, 05:06 PM
James1750's Avatar
Andrew
Thanks Andrew - bugger, thought the factory manual might cover it off......
This may be a tough one to find out (without the correct measuring tools anyway.....)
If anyone can help out in this dept. it'd be greatly appreciated
James
James
Old 06-18-2007, 10:35 AM
papajam's Avatar
papajam papajam is offline
From memory, so don't quote me on it, the pinion mounting distance (or pinion depth as measured from the face) is 57mm plus/minus the figure (in hundredths of a millimeter) stamped on the pinion. The crownwheel distance is variable as the distance is determined by the crownwheel backlash.
I'll check the books tonight...
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 06-18-2007, 05:03 PM
James1750's Avatar
Thanks a heap Jim.... you truly are a wealth of knowledge...
I'm after the axes offset in my diagram (or hypoid offset)..
James
Old 06-18-2007, 07:16 PM
papajam's Avatar
Sent you a PM.
