Snake oil and mouse milk, in this case are probably best used with the heater valve closed
. The stuff does build up, and can be over applied
. As has been mentioned, the best mouse milk/snake oil can still build up in the cooling passages of the radiator
. Usually a flush takes care of it, while still leaving enough residue in the crack
leak, to maintain a seal
. Also as has been mentioned, race engine builders often apply this cure to freshly rebuilt engines. I've run Bars Leak in my sand cast GTA head for years (I do flush, and reapply periodically) without radiator problems. I use distilled water. The Bars Leak has both a water pump lube and anti electrolytic, like antifreeze, to slow internal corrosion. Zinc annodes are also good for this purpose if one runs water as a coolant
. Plugging up borderline useful Alfa heaters with any of the mouse milk / snake oil concoctions it too horrible to consider
. (Unless it leaks too!
Gordon Raymond
