Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Sedan (1963-1974)
Old 05-08-2007, 05:02 PM
acurtiss's Avatar
acurtiss acurtiss is offline
Send a message via Yahoo to acurtiss Send a message via Skype™ to acurtiss
horn gremlins
Does anyone have access to a schematic of how the horn button is assembled on a Giulia Super? Mine has an embarrassing tendency to make contact when I'm not even in the car, eg, in my driveway at 5am. I had it apart once and I'm not 100% sure I put it back in correctly. The inner button doesn't want to 'seat' as well as it seems like it should.
1967 Giulia Super (blk plate), 1969 BMW 1600 (blk plate), 1968 Citroen DS (blk plate), 1962 Corvair Rampside, 1965 Honda CB77, 1957 Vespa Allstate
Old 05-08-2007, 07:27 PM
sono veL.O.ce's Avatar
sono veL.O.ce sono veL.O.ce is offline
HA! Welcome to the neighborhood.
How many motorbikes have you got back there?
'66 GTV rolling chassis --- '74 spider(heirloom) --- '64 Giulia Ti --- '74 GTV sold! --- '74 GTV sold!
'6x DUCATi 250cc cafe racer.
Old 05-08-2007, 09:48 PM
rogerspeed's Avatar
rogerspeed rogerspeed is offline
Have you checked the connections and wire at the ends of the stator tube? Down by the steering box they crack from the header heat, at the other end you need the cover on the bullet connector, the insulation will rub off where it goes through the hub depending on the arrangement, not sure how your button assembles.
'83 Rabbit LS Diesel,5spd,4dr,S/R
'67 BMW 1600ti/Alpina
And Looking For Another
www.resoles.com
"just say no to reductionism"
Old 05-08-2007, 10:23 PM
acurtiss's Avatar
I'm sure it's in the button assembly - it's too sensitive in normal operation and will often stick 'on' unless I shift the button a little. The connectors are good and protected with their rubber sleeves.
The horn was not connected when I bought the car, so my original disassembly was to get it working again. Luckily -- or not -- only the high-pitch horn is working (thanks to prior early morning episodes, the low-pitch one is now kaput). I'm getting a replacement set but I want to fix the button problem before I install it.
And veLOce, I'm at 3 bikes. Two of them are just noisy. The third is noisy and also emits a beautiful and steady plume of two-stroke smoke. I'm sure my neighbors love me.
Old 05-09-2007, 07:05 AM
Andrew Andrew is offline
I'm working from memory, without a parts book, but here goes.
Lowermost is the hat section piece with the small tang and screw that the horn wire attaches to. It goes with the tang/screw downward (towards the steering box).
Next is a plate that fits in that hat? Not sure here.
Next is the big spring.
Next is the horn push assembly with the button, surround rim that fits into the steering wheel boss, with its spring clip.
Don't forget the rubber bung that centers the horn wire in the steering wheel attaching nut.
I have my parts book at home, but someone might chime in before I can get to it. Sorry if my memory's screwy.
Andrew
Old 05-09-2007, 11:12 AM
acurtiss's Avatar
I'm beginning to think my Giulia has a sense of humor: the ghost horn trick happened again this morning, as I was taking a shower.
Thanks for the help Andrew. I'll take a look tonight when I get home and see if it matches what you've described.
Old 05-09-2007, 11:28 AM
I've seen it happen that everything was properly arranged at the horn button, but the wire was shorting inside the steering column. But first things first.
Andrew
