Old 05-07-2007, 02:45 PM
boxcarracer boxcarracer is offline
Need help identifying Solex carbs. & more.
Hey guys,
Cleaning out my shed the other day, I found double Solex carbs.
I haven't had time to clean them or look for stampings to check for a model number or something.
Would someone know what model they are (so I can buy a rebuild kit) and what car they originally came off?
Further, can anyone give me an approximate value for the following:
1 Biscione hood (Solid with no rust holes)
4 Biscione doors w/handles&cards (same comment as above)
1 Biscione front windshield (I assume these are standard Giulia parts)
1 Biscione rear glass (same comment as above)
Luigi
Old 05-07-2007, 03:50 PM
nochicken's Avatar
nochicken nochicken is offline
1966 Giulia Super
Originally Posted by boxcarracer View Post
Hey guys,
Cleaning out my shed the other day, ...
Luigi
Does anyone know if the Biscione front and rear glass would fit a 1966 Giulia Super? If so, I may be interested in those. Price?
Frank
Current: '66 Giulia Super
Former: '78 Spider
Website: http://www.geocities.com/nochicken2002/alfa
Old 05-07-2007, 03:53 PM
I'd first like to know their approximate value. I'm quite certain they'd fit.
However, I'm also quite certain I won't sell any of the mentioned items, they're quite hard to come by and we might need them as spares one day (God forbid) .
Thanks for the interest.
Luigi
Old 05-07-2007, 03:56 PM
nochicken's Avatar
1966 Giulia Super
My bad...thought I was over in the spares forum If I had them, I'd hold onto them, too.
Frank
Former: '78 Spider
Old 05-08-2007, 06:49 AM
super1750's Avatar
super1750 super1750 is offline
The carbs look to me to be the model DDH40 with a suffix number somewhere between 3 and 7. The rep kits are different than those for the more common ADDHE40's which followed the DDH'S but both are available (at least here in germany) for about 30 Euros.
Have a closer look at the carbs and PM me and I'll send you adresses, or order the rep kit here and send it to you when i move to canada in a few weeks.
regards
Bob (solex warrior)
BTW: If they still have the little aluminium tags on them, they are stamped with the Alfa model number (ie: 101.xxx, 105.xxx, 115.xxx) which tells you which model they were originally on. If not, you can start by measuring the main venturis and go from there. The model Number of the carbs is on the left barrel of pic #2.
Current Alfas:95 145 1.7l-16v boxer, 71 Giulia 1300 Super (2.0) ;-)
Old 05-08-2007, 07:13 AM
^Thanks alot for the info I'll check them out by the end of the week and then message you.
I'll then start taking them apart and try to find an acid(?) bath the put all the metal components to remove all crusts/oxidation/crap.
Luigi
Old 05-08-2007, 07:18 AM
super1750's Avatar
Solvent of sime kind should do the trick. If you use acid you probably won't need the rebuild kit any more!
Bob
