Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Sedan (1963-1974)
Old 04-30-2007, 05:32 PM
nochicken's Avatar
nochicken nochicken is offline
1966 Giulia Super
Carpet
Has anyone had any experience with Auto Carpet Professionals? See their ebay link:
http://cgi.ebay.com/ebaymotors/1965-...QQcmdZViewItem
I'm planning on doing my Super carpet and have so far liked the samples that Fryer's Auto Upholstery sent out but saw this link on Ebay and thought I'd see if anyone had tried their carpet.
Frank
Current: '66 Giulia Super
Former: '78 Spider
Website: http://www.geocities.com/nochicken2002/alfa
Old 05-01-2007, 07:29 AM
Andrew Andrew is offline
No experience. They look pretty generic, so I'd be wary without some firsthand attribution or more info.
I got my wool carpet kit from World Upholstery in Camarillo CA and am 95 percent happy with it. One piece was a hair too short, and the color is not quite what I'd like, but I knew that from the samples when I chose it, that they didn't have a grey that matched the original.
Andrew
Old 05-01-2007, 08:07 AM
sprintgtc sprintgtc is offline
I've never had a good experience with pre cut carpets. You will be better served to buy the carpet you like at an upholstery shop. For a Super, you'll need about 4 yards. Use your old carpet as a pattern and cut new pieces. Have the upholstery shop bind the edges. It will be cheaper, too.
Mike Macaulay
Seattle
84 Spider Veloce 69 GTV 66 Giulia Super 64 Giulia GTC 57 750b
Old 05-01-2007, 05:52 PM
nochicken's Avatar
1966 Giulia Super
I've been thinking about going the route of buying yards of carpet and cutting to size but am not sure I can get a decent price to bind the edges in the $$$ Washington DC area. As well, the front carpet pieces are pretty torn up to use as templates.
I thought the Frey's carpet looked to be a pretty good match color-wise, but it really is a very small sample to compare.
I have some time before I attack this and will try to get a few more samples to check out.
Frank
Former: '78 Spider
Old 05-02-2007, 10:51 AM
gmack gmack is online now
carpet
For what it's worth, I've had good luck using old, even torn up, mats and carpet as templates for new.
In Minneapolis, I've typically paid $2/foot for vinyl binding that looks pretty stock. They've even been able to add heel pads for the drivers side as well as the padding on the tunnel.
GMack
74 GTV
69 Spider
Old 05-03-2007, 09:05 AM
The upholstery shop in Seattle charged me about $130 to do the binding work on my Super. The carpet was $180-ish. (obivously, not wool) As GMack says, you don't need much more than scraps for the templates. If your having trouble, make templates from butcher paper and test fit. Here's my Super carpet:
Mike Macaulay
Seattle
Old 05-03-2007, 09:43 AM
Bill S Bill S is offline
Hi Frank,
My Super project car came with a nylon carpet set that I think came from Hurtienne in Germany. It won't get installed for another year so you're welcome to compare it to your tattered templates, even take a couple pieces to your upholsterer as long as I get them back! You need an excuse to drive your Super up to the mountains of western Maryland anyway.
Bill Sinclair
Old 05-03-2007, 04:35 PM
nochicken's Avatar
1966 Giulia Super
Thanks for the offer Bill. Later this summer I will make that trip! The Super is still in undergoing body work (good, cheap, fast--pick any 2) but will no doubt be out in another month or so.
I'm going to look more into buying the "bulk" carpet. From the posts, the binding costs apparently are not too nasty.
Generally, I'm moving so slowly on the Super fixes/upgrades I figure I can drive it around for awhile without carpet.
Frank
Former: '78 Spider
Old 05-03-2007, 04:39 PM
nochicken's Avatar
1966 Giulia Super
Mike,
Thanks for posting that photo. It looks great--a real nice rich red look.
The existing carpet in my Super is the dark gray (almost black) and I'll probably stick to that. I'm encouraged that the binding is not a complete bank account buster.
Frank
Former: '78 Spider
Old 08-26-2007, 06:21 PM
nochicken's Avatar
1966 Giulia Super
Carpet Update
I decided to go with the Fryer's carpet and was pretty pleased with the quality, match to old pieces, etc.
Of course, once I dove into the project, I decided to scrape much of the old sound deadening panels, POR-15 a bunch of areas, and add new Dynamat. The floors were actually in decent shape considering the original state of a couple of the body panels and outer rockers (rust-wise).
Thus, I'm about half-way through with the passenger side done up through padding and the long, narrow side carpet piece that fits under the trim strip. That piece is really kind of a PITA but with that in place I think the larger pieces will be pretty easy.
If anything, I guess I am mildly surprised that:
1. The screws holding the carpet/pad go right through the pan. I would have thought there would have been some better provision (i.e., so that water couldn't get in).
2. Similar to #1 for the two threaded studs that hold each side of the seat. These go right through the floor. I'm going to add some kind of glop to seal those holes.
3. I was amazed the nuts attached to the seat threaded studs came off as easily as they did. Would have thought after 40 years they would have presented more of a challenge to remove. Definitely relished that.
4. I found two holes (look factory drilled) in the rear pans (passenger and driver side) that go to nowhere. These are getting filled.
I'm debating whether I should take on the door weatherstripping and headliner repaint while I've got everything apart. But, I may just wait until it gets colder--kind of hard to drive it without the driver's seat installed.
Frank
Former: '78 Spider
Old 08-26-2007, 07:34 PM
alfa2go's Avatar
alfa2go alfa2go is offline
Originally Posted by nochicken View Post
3. I was amazed the nuts attached to the seat threaded studs came off as easily as they did. Would have thought after 40 years they would have presented more of a challenge to remove. Definitely relished that. .
Lucky bugger, mine snapped
I'll be interested to see which way you go with the door seals, as in the ones on the body. Are yours the furry ones or straight rubber like on the later sedans?
I am about to put my new windscreen in so I am going to rejuvinate my headliner too.
Derek Entesano
'66 Giulia Sprint GT (Resto) AR 753540 Rosso
'66 Giulia Super (Daily Driver) AR 721136 Biancospino
'65 Giulia Super (Donor) AR 720236 Bluette
Old 08-26-2007, 10:16 PM
101/105guy's Avatar
101/105guy 101/105guy is offline
Boy, this was a major factor in getting the '68 super from Germany. the original interrior needs nothing! Refreshing the interrior of the Duetto was a pain and it only has two seats!!
'65 Guilia Spider
'67 GTV
'67 Duetto-in progress
'68 Giulia Super
'70 Giulia 1600 'S'
Old 08-27-2007, 01:15 PM
nochicken's Avatar
1966 Giulia Super
Carpet
101/105 - I envy that interior--looks nice. Redoing mine (I keep telling myself) is a great way to learn about the sedan details
Derek - I went with the fuzzy seals. It doesn't seem like it will be as difficult as the seals on the door themselves (another future task). For the headliner, I was going to remove the glass during the bodywork session but backed out due to time constraints and worry about breaking the glass. For now, since the headliner is really just discolored, am going to paint it.
Frank
Former: '78 Spider
  #14 (permalink)
Old 08-27-2007, 04:40 PM
101/105guy's Avatar
I can recomend SEM paint for your headliner. Use their prep solution to clean and soften it first.
'65 Guilia Spider
'67 GTV
'68 Giulia Super
'70 Giulia 1600 'S'
  #15 (permalink)
Old 08-27-2007, 04:44 PM
alfa2go's Avatar
Where did you get the fuzzy seals and what were they worth? Its cool that everybody is starting to give their giulias a bit of love!
Derek Entesano
Articles
