I have a Glenn's ALFA manual reprint, they are available from the usual sources, there is a very detailed, full page of small text print that describes the complete charging system test(s) and proceedure (for generator equiped alfa models). I don't have a scanner and it's complicated, depending on the brand of regulator, but let me try to assist. You can test with ammeter, they stress that when you test the generator with the regulator disconected, don't race the engine as with no regualtor in the loop you can burn out the generator also if the generator is being replaced/repaired because of no output, the regulator should be replaced, because generators generally fail because of faulty regulaors. They recommend that you slightly discharge the battery before trying any tests, (crank with the coil wire disconnetced). Then start the car and do the charging test, keeping in mind that the charging rate should decrease. Anyway the manual is Brookland reissue. Great stuff for the older cars.
1) test battery
2a) test generator output > low output >repeat test with ground jumper; output now ok. clean and tighten connection and or replace ground cable; OR output less than normal> perform elctrical tests on generator repair or replace parts as required
2b) test regulator > regulator not ok > adjust, repair or replace faulty unit
2c) test external resistence circut > resistance normal> battery run down from excessive or unusual drain; OR resistence excessive > clean and tighten or replace cables or regulator
'83 Rabbit LS Diesel,5spd,4dr,S/R
'67 BMW 1600ti/Alpina
And Looking For Another
www.resoles.com
"just say no to reductionism"
