1972 Berlina speedometer cable replacement - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 04-19-2017, 08:59 PM Thread Starter
bshorey's Avatar
Send a message via AIM to bshorey Send a message via MSN to bshorey Send a message via Yahoo to bshorey
Hey All,
I'm trying to replace the speedometer cable on my '72 Berlina, and having a bear of a time. I can't reach the back of the speedometer to undo the cable. I have another gauge panel on my shelf, and it has two tabs on the bottom, they look like they hold the gauge panel in place.
I've tried using a screwdriver and putty knife to access those tabs on the gauge panel that's in the car, but I can't get the panel to pop loose.
What's the trick? Is there a way to get those tabs to move from the front, do I need to access them from the rear, or?
Looking at the part that's on my shelf, if I can get those tabs to pop, the panel should come out through the front, and I can access the speedo cable that way.
Any help is appreciated.
bs
bshorey is offline
post #2 of 3 (permalink) Old 04-21-2017, 06:01 AM
Andrew's Avatar
The two spring clips you get at through the slots cast in below the instrument binnacle. Insert screwdrivers, push up on springs, binnacle hinges from the top. See pic.
Andrew
Andrew is offline
post #3 of 3 (permalink) Old 04-21-2017, 08:29 AM Thread Starter
bshorey's Avatar
So simple, never even noticed there were holes there!
Thanks so much Andrew!
bs
bshorey is offline
Replace with
