1750 engine in an A12 - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 10-21-2014, 09:57 AM Thread Starter
Hi folks,
I own an A12 with an original 1300 petrol engine. The van is pretty heavy, so i was wondering if it's possible to mount 1750 (00548) engine in it to give it a little bit more power.
Has anyone of you got any experience with such a modification?
What are the «main problems» that I will encounter?
Thiago is offline
post #2 of 4 (permalink) Old 10-21-2014, 12:39 PM
The main one will be stress on the driveshafts. I've heard rumours of a few people trying this, and then ending up with the rather more difficult issue of finding new shafts...
bigwill is offline
post #3 of 4 (permalink) Old 10-22-2014, 08:16 AM
Andrew's Avatar
They came new with both 1300 and 1600 single-carb engines, so unless you keep your foot to the floor all the time, I wouldn't worry too much about increased torque. I had an F12 with Perkins diesel, which has 75-80 ft/lbs of torque, drove it flat-out cross country.
The u-joints are huge, and I would think are up to the torque if in good condition. Much bigger than 105/115 type, and not easily replicated in the US. I had one cup that was slightly loose, and the driveshaft shop that examined it for me was pretty awestruck about the size and strength. I had the whole LF hub and driveshaft off, and it's very substantial stuff. Again, if the condition is good, I wouldn't worry about the extra torque unless you build a race motor and run it wide open.
See my F12 thread for pics of the hub and u-joints.
Andrew
Andrew is online now
post #4 of 4 (permalink) Old 11-30-2014, 11:51 AM
thomfr's Avatar
A friend of mine drives a F12 (in Germany) with a 1750 engine but with a single carb because the dual fitment would sit far too wide in the passengers legroom. Had a lot of stress with jetting it correctly.
He used a diesel gearbox because of the longer ratio.
Thom
It all started with a very popular coupé that was winning everything without having anything particularly special.
Carlo Chiti
thomfr is offline
Replace with
