147 1.6TS shows DTCs - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 12-01-2016, 10:57 AM Thread Starter
A friends 147 1.6TS of 2001 (Euro model) shows DTCs P0141 and P0136 for a short time:
P0141 : Preheating resistance 1 below catalyser
P0136 : Lambda 1 signal below catalyser
Description says, that the problem is in the heater circuit of the lambda-sensor heater, most likely the relay itself or the wiring to it or from it.
DTCs can be cleared, but appear again at colder start.
So, where precisely is this relay located, unfortunately - as the car is not mine - i have no schematics and no service manuals.
Thanks!
164 2.0 T.S 8V (5/1992, Euro spec.)
Max32 is offline
post #2 of 3 (permalink) Old 12-03-2016, 06:25 AM
You can check which parts you need here
FIAT ePER
Is the 147 in a country where Alfa is/was active when the 147 was in production. If so, go to a dealer or Alfa specialist for tips or guidance.
Erik is offline
post #3 of 3 (permalink) Old 12-03-2016, 08:06 AM Thread Starter
Thanks a lot, i told the owner do disconnect the 2 connectors, clean them and measure resistance of the probes heating elements, should be the 2 white wires.
Somewhere here i located a wiring diagram for the GTA, there are all 4 heating circuits in parallel sourced from one fuse and one relay, therefore theese 2 sensors also should be wired in parallel and therefore no defective fuse or relay, as the DTC is only for one sensor.
>dealer or "Alfa specialist": the more we can check ourself the better...
Max32 is offline
Replace with
