Alarm fault / Code fault - Giulietta - Alfa Romeo Bulletin Board & Forums
post #1 of 2 (permalink) Old 06-27-2016, 01:49 AM Thread Starter
Unhappy Alarm fault / Code fault - Giulietta
Hi,
I have a fairly annoying problem with my 2013 Giulietta, in the last 2 months upon trying to start the car I've been getting the car lock icon on the dash (when referring to the owners handbook its called an Alarm fault / Code fault) and the car won't start - it will either crack very shortly or won't crank at all.
Only solution I've found so far was to lock the car and wait for a few minutes which seems to do the trick.
Car is past its warranty so before going to the dealer, is that a known problem with an easy fix? couldn't find similar problems on here...
Battery is six months old and the car is used as a daily driver so i doubt it has anything to do with it.
Any help would be gladly appreciated!
alonroz is offline
post #2 of 2 (permalink) Old 07-12-2016, 09:37 AM
I can't help with the starting problem.
This Alfa BB is based in the US and Canada. The Giulietta 940 are not sold in either country.
Take your problem to The site for Alfa Romeo Owners, its based in UK and you can get help there. Lots of Giuliettas in Europe.
Erik is offline
