Go Back   Alfa Romeo Bulletin Board & Forums > General Forums > Picture Room
Old 05-01-2008, 12:19 AM
baboon baboon is offline
V8 Turbo F1
Bonjour à tous
Photos Emilio A (Alfa Classic Club France)
Museo Alfa Romeo Arese
Old 05-01-2008, 12:21 AM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Now how cool is that
Darren
'84 manufacture - '85 MY Spider Graduate
Old 05-01-2008, 01:48 AM
la_strega_nera la_strega_nera is offline
Isn't that the Indycar motor?
1966 Giulia Sprint GT Veloce
1971 Ford XY GTHO (replica) race car (For sale?)
1982 Suzuki "Bathurst" Katana
1985 Suzuki RG500
1995 Cagiva Mito (race kitted 250 powered)
Old 05-01-2008, 02:04 AM
sh0rtlife's Avatar
sh0rtlife sh0rtlife is offline
that would be fun to shoehorn into a gtv6!!!!!..or should i say GTV8!!
[SIGPIC][/SIGPIC]
Old 05-01-2008, 05:08 AM
Smurf's Avatar
Smurf Smurf is offline
Send a message via MSN to Smurf
out of this world...
Alfa Romeo, Maserati, Lamborghini... could life be any better ???
Old 05-01-2008, 10:58 AM
bianchi1 bianchi1 is offline
why a gtv..put that thing in a spider..my spider
don't follow me,i'am lost
Old 05-01-2008, 11:12 AM
treborblack's Avatar
treborblack treborblack is offline
wow that's what you call a turbo
Driving a September 1996 super like i stole it
Old 05-01-2008, 12:54 PM
Andrew Andrew is offline
The car does say Patrick Racing on it, so it must be the Indy car, not an F1 car.
Andrew
Old 05-01-2008, 01:34 PM
modena782002's Avatar
modena782002 modena782002 is offline
Wasn't the Indy car motor the old F1 motor? I thought that I read that somewhere. CRS lately though.
Nick D'Eri
1968 Fiat Dino Spider 2.0
2003 Saab 9-3 Linear
2008 Piaggio Fly 50
1977 Peugeot 103 Moped
Former Italians:
1992 164S 2002 - 2008
1981 Spider Veloce 2001 - 2003
1974 Fiat 124 Spider 1979 - 1981
Dad's Former Italians:
1962 Giulietta Spider 1964 - 1969
1969 Berlina 1750 1970 - 1971
Dignity...at all costs
Old 05-01-2008, 03:58 PM
raff_gta's Avatar
raff_gta raff_gta is offline
sweet as! anyone got the cash (and balls) to put it in a road alfa?
Old 05-01-2008, 04:21 PM
F1 turbo cars were 1.5litre, Indy cars are 2.65(?)
Did alfa ever have a v8 turbo in F1? I thought it was a N/A Flat 12, or a turbo 4cyl?
Found this over on the Atlas F1 board (from the original March press release):
The Alfa Romeo engine for Indy car racing was designed by the team of designers led by Claudio Lombardi and consisting of Giovanni Roffina, Luciano Caruso and Giuseppe D’Agostino. This brand new engine has been built in record time. In October of 1988 it was still on the drawing board. In February 1989 it was running on the test bench. Just a month later, it was completing its first laps in a March 88C “muletta” test bed at Monza, with drivers Bruno Giacomelli, Roberto Guerrero and Giorgio Francia sharing the wheel. Classic technical solutions have been chosen to first and foremost ensure reliability, it is a 90-degree 8 cylinder V-shaped engine with aluminium crankcase and cylinder heads. Timing is based on one double overhead camshaft per bank and four valves per cylinder. Valve caps and other minor parts are made of magnesium. The 2648 cc displacement is achieved with a cylinder diameter of 86 mm and a stroke of 57 mm. Intake is at the center of the “V” and exhausts are lateral. The architecture of the engine has been designed to enhance the car’s aerodynamics, i.e. the engine must not interfere with the “tunnels” under the body, which exploit the Venturi downforce effect which is vital in Indy car racing. Neither should the engine’s height disturb the flow of the air toward the rear wing. Turbocharging is provided by a Garrett Turbo coupled with a waste gate and CART specification pop-off valve. The Magneti Marelli indirect electronic ignition with two injectors per cylinder is integrated with the ignition. This is of a static/direct type with capacitive exhaust. The small ignition coils, in other words, are mounted directly on the spark plugs. The designers have paid special attention to fuel feed and combustion because pure methanol is the specified fuel. Methanol has two fundamental properties which make it stand out from other fuels. Its heating power (i.e. number of calories per unit of weight) is about half that of gasoline and specific fuel consumption is double. Its latent vaporization heat (the calories necessary to vaporize one unit of weight) is two to three times higher than that of gasoline. This creates big problems in starting and in operation under partial loads. However once normal running temperatures are reached the calories taken from the air by the process of vaporization of the mixture actually have a cooling effect in the intake area, negating the need for an intercooler. At the current stage of development the engine has a power of 680 BHP at 11500 rpm and weights 342 lbs. Its extreme compactness has facilitated its accommodation into the March-built chassis.
more pics of car and engine here
1985 Suzuki RG500
Old 05-01-2008, 04:58 PM
aralfa8589 aralfa8589 is offline
Thanks for that last post. That is one of the coolest engines I've ever seen.
Jeff Lang
'85 GTV6 3L, '89 Milano Gold
'91 164S, '91 164L
'89 Spider
'74 GTV project
Old 05-01-2008, 05:04 PM
Oh, and while I think about it, there was one on Ebay about 6-7 years ago... I did briefly consider it... there was a DTM motor in about the same period too.
1985 Suzuki RG500
  #14 (permalink)
Old 05-01-2008, 05:16 PM
SpiderWebb's Avatar
SpiderWebb SpiderWebb is offline
I was curious as to when Alfa started the Indy connection and why it ended. This is a great time line by Pat Braden. For the full article go to:
Info Center
Alfa Corse/Autodelta History
"One fact that lacks a clear cut reason was the opening of a US operation in the late 1980s and an attempt to enter Indycar racing. Perhaps it was at the urging or Chrysler, their US marketing partner for a while, who could have emphasized the importance of Indy to the American racing scene. While the effort went on for three years with first rate teams and chassis, the effort was abandoned with little success (similar to the results of Porsche and Honda, it seems!)
- Pat Braden"
1981 Spider 2000 USA - It's SpiderWebb cuz' Webb's my last name.
  #15 (permalink)
Old 05-01-2008, 07:59 PM
Thank you la strega nera and Spiderwebb for setting me straight on that.
Nick D'Eri
2008 Piaggio Fly 50
Former Italians:
