07-04-2007, 12:29 PM
Hello Andreas!
Great car!
What paint code of yours GTV Bertone?
Thanks.
07-04-2007, 03:52 PM
Originally Posted by Gabor K.
I'm a little doubtful of the 248hp.... what exactly has been changed on this head to produce that sort of power? Admitedly it is darn expensive and you normally pay for large HP so it may be plausible......
More information if you can please
James
1968 series 1 1750 GTV (RHD)
07-05-2007, 03:47 PM
This engine was in the Autovama Alfetta GT winning the European Gr. 2 series late in the seventies. To our surprise then, it was not a 16V engine in it but the GTAm evolution engine. This car is included in a racecar survey in Sport Auto in 1979, so I still have this clip. Not much is mentioned in the specs, but here it is:
4 cyl in line engine 1985 ccm ( in reality 2012 ccm)
Bore X stroke: 85,1 X 88,5 mm
Power: 182 KW / 248 Hp at 8000 rpm
Torque: 230 Nm at 5800 rpm
Injection: Spica
Sump: wet
Compared with the Bertone GTAm engine 1971, data from the Fusi book
Volume: 1985 ccm
Bore X Stroke: 84,5 X 88,5 mm
Power: 210-240 HP SAE at 7500 rpm
Injection: Spica
Interesting difference to the road 2L engine is a little different bore and volume, and head of course:
Volume 1962 ccm
Bore X stroke: 84 X 88,5 mm
A couple photos of the Autovama champion cars.
07-05-2007, 04:49 PM
Injection: Spica
Sump: wet
Volume: 1985 ccm
Injection: Spica
Volume 1962 ccm
I'm now a believer - thanks for the details
James
11-04-2007, 06:28 PM
That conversion is pure sex!
I can't believe it's virtually a straight bolt up :|
11-04-2007, 07:56 PM
Originally Posted by andreas_alfa
I wish but the old one even spend alot of money to change internals (pistons, rods, valves, cams ect..) May reach up to 180hp @ Crank with errors such as oil leaks from the gasket and could blow at high abuse point. I had alot of bad experience during the last 20 years while racing my alfas, till the point that the crank breaks. The Sr is a clear same configuration engine, but with japanease reliability. This engine can reach with stock internals 350hp @ crank, and if change the internals 600. I wish i had the money to install a maserati v8, possibly my next project.
Andreas
The SR might make 350hp on stock internals, but not for long. My machinest builds SRs quite often, and rebuilds them just as often when the drifters go out on stock internals, crank the boost and blow them up. No the Alfa engine won't make 200 hp easily, but it also would need full race tires to use it anyway. I have a 40 year old engine that makes about 200 hp at the flywheel, I have 45000 miles on it as well, runs carbs, and even gets good milage as long as I dont stand on the gas (about 26mpg turning 4500 rpm on the freeway.) With street tires, I absolutly cannot use the power, the car becomes a tail happy beast that is slower than everything else in its autoX class. With a change of tires, it becomes a class winner. I don't know if an alfa with that sort of power would do better or worse on street tires, but I'd love to find out. The engine does make the car, if its gone (or doesn't at least look correct with the car (example, a 1300 being replaced with a 1600/1750 or 2L alfa engine) the car becomes something else with the wrong skin. I'd rather see the correct(ish) engine making lots of power than something modern any day of the week.
I have never and will never see the reason to swap a modern engine into a vintage car. If you bought the vintage car (doesn't matter what it is) and want to swap something modern in to it, just buy the modern car in the first place because thats what you end up with.
That said, the body work and paint are beautiful, and the install was cleanly done.
Will
1959 101.02 Sprint AR1493*20198 (project) 1969 1750 105.51 GTV AR1530324 (driven daily)
01-14-2008, 06:40 PM
Andreas Alfa you never really answered the question about the brake system. I understand you put BMW calipers. Were thesw direct bolt on or what modifications did you do?
01-26-2008, 11:07 AM
Oh Im sorry i thought i did, Well the brakes bolted straight on with no modifications at all.
andreas
[COLOR="Black"][B]Current rides
Alfa romeo '74 Gtv 2000 turbo
Aprilia '03 Rsv 1000 mille[/B][/COLOR]
[COLOR="Red"]Previous rides
Cars
First car (Alfa GTV 2000 Veloce), Guiletta, v8 Commodore, Alfa 33, Bmw 318is, And Alfa GTV 2000 Turbo once again..
Motorbikes
Honda cruiser, VMAX Yamaha, Kawasaki zx-12 Ninja, Aprillia RSV [/COLOR]
07-15-2008, 06:47 PM
What a fantastic job - love it!
1981 Sprint Veloce-sold to a great new owner
1979 Series 2 Chrome Bumper Sud Ti 1.5-sold to professional restorer!
07-15-2008, 07:36 PM
Nice work! Have you got any videos of it?
As someone else mentioned, the only change I'd make is a set of period wheels. But I suppose that may not be possible with the bigger brakes.
- Luke -
10-13-2008, 01:16 PM
Very neat conversion, I will let others pontificate about if its an Alfa or not but I would happily have a 8C with its Maserati/Ferrari motor in my garage and call it an Alfa, while I would not call the Arna with its brilliant Alfa Sud motor an Alfa at all. Most modern Alfa’s have Fiat or even GM motors!
Anyway very neat conversion, for those of us in this part of the world it makes a lot of sense, I’ve just seen winged sumps available for the SR20 and not even that expensive, I am thinking about doing this in a Berlina and wondered if you could post some photo’s of the engine mounts and underneath the car , gearbox etc.
10-16-2008, 11:52 AM
Cool beans
I love it, what a cool setup. More fun,more power and looks pretty straightforward. Hot rodding at its best. Are these SR20 motors pretty easy to find or sought after by the drifter crowd?
Peter Inshaw
San Jose, CA
63 Giulia Spider - vintage racer
67 GTV - vintage racer
67 Super - kids project
91 Spider Silver
91 Spider Red (FS)
10-16-2008, 06:17 PM
gtv
That is a sweet silver and nicely applied I might add. Most people don't like the wheels, however the finish goes perfectly with the colour and bright-work! You might not want to reveal the colour but how about a hint?
10-16-2008, 07:25 PM
I am in New Zealand currently looking at buying a mint front cut from a damaged Silvia, 65000km, SR20DET which comes with engine/gearbox driveshaft electronics etc etc for about $3500NZ, yes they are sought buy the drifter crowd but their are so many available price is not a problem, I'm sure you know teh cost of getting a nord motor to 200hp, even a T/S will be 4-5 times that amount, not to mention a robust and cheaper to repair gearbox , getting rid of the donut and the ability to tune to 250hp very very easily.
10-17-2008, 07:57 PM
more of the same
i looked online and the entire setup is at most $1800, with engines running from 400 to $750US. Looks like there are a lot of engines from Japan. Look like the oil pan is narrow enough to fit a Giulietta as well, curious, curious.
Peter Inshaw
San Jose, CA
91 Spider Silver
91 Spider Red (FS)
