Old 10-09-2003, 12:23 PM
Bill's Avatar
Bill Bill is offline
Cool Monthly Warrior
What happens when an old fa*t gets it in his head to go out and play whith the kids.
This is a shot of Sophia & me in the Oct. AutoX here at A&M. Playing games with Z cars and Miatas. Did alright but think my suspension is in need of updating (all original).
Any recommendations? Want to stay in E-stock so no poly bushings or harder springs.
Thanks, Bill
Get out there and DRIVE!!!
Bill
'78 Spider
Old 10-09-2003, 02:21 PM
John M's Avatar
John M John M is offline
Alfa Poor in KY
Hey Bill:
First....and foremost, I must say that Sophia is looking stunning. You have done a great job making her shine.
In regards to suspension, what can you do and stay in your class? First things I would have said would have been stiffer lower springs, poly bushings, and konis....but I already see from your comment that the springs and bushings are out.
Best Regards,
John M
Old 10-09-2003, 03:54 PM
Bill's Avatar
Thanks John, we appreciate the complement!
According to SCCA rules on stock classes, nothing can change that was not a factory installed option for the model, as far as suspension mods go with the exception of shocks , brake pads and exhaust past the Cat.
I can put in new bushings and any other "options" available from the factory. Since "poly" was not an option, nor was shorter/tighter springs, those are "technically" out.
I have already installed Koni reds on the front, I will follow up with the rear pair next month.
She does not handle badly, just "loose and tired" feeling. I have thougt about new "factory" springs but what's the advantage. I dont know if these are worn out ,but after 25 years I would suspect they are.
Anyway, I'm having fun and just want to be a little more competative.
Thanks again!
( here is another view)
Bill
'78 Spider
Old 10-09-2003, 04:37 PM
John M's Avatar
Alfa Poor in KY
Well....here is food for thought and a head long dive around that rule in regards for the springs.
The euro version had shorter springs. Only in North America did the spider ride so high and have the heavy rubber bumpers. So in essence, there were factory springs that were shorter that should be completely legal. Also the euro bumpers which are lighter.....should be legal as well. I cannot help though on the polys.
Best Regards,
John M
Old 10-10-2003, 12:10 AM
PSk PSk is offline
If the car feels loose then maybe you have some bushes that need replacing.
Thus replacing with standard rubber bushes will make her better ... after all after 25 years all bushes are probably on the stuffed side.
Also springs to get old and actually get longer and raise the car. If you buy new springs they will be shorter.
I think the best you can do is:
1. Replace your rear shocks as you stated.
2. Replace all suspension bushes - ie. a full suspension rebuild.
3. Replace your springs with standard but new springs.
4. 4 wheel wheel alignment, maybe with some careful work to setup the camber, caster the best you can with standard parts.
Old 10-10-2003, 10:33 AM
RogerB RogerB is offline
Best Regards,
John M
Parts had to be factory options for cars sold in North America. (Or was that "U.S."?) I know some guys have tried to get around this rule with the Ford Mondeo/Contour, but it's a no-go.
That said, I would agree with upgrading your dampers as much as possible, and refreshing all of your bushings with OEM rubber, since stock category rules out poly. Not sure about springs wearing out and getting taller? Seems counterintuitive, but...
Anyway, if it's not too much rework, I'd do dampers and bushings and see where you are. After that, maybe new springs.
Also, I'm not sure if it would help this car, but your front swaybar is also open, is it not?
Old 10-16-2003, 05:45 PM
PSk PSk is offline
Yes I know it sounds like rubbish but here is what happens. The ability for the steel to continually return to their correct sitting position reduces thus the spring (when uncompressed) is actually longer.
Thus if you buy a brand new spring and obtain an old one of exactly the same specifications the new spring will be shorter than the old one ... when both are uncompressed.
I was surprised too when I replaced springs on my car many years ago.
Anyway a spring definately wears out.
Old 10-16-2003, 07:07 PM
Alex Csank's Avatar
Alex Csank Alex Csank is online now
Send a message via AIM to Alex Csank
Hmmm, it sounds like you are trying hard to make it hard on yourself!
Look, I would never suggest bending the rules, but if you were to get some IAP or Centerline springs and re-paint them black to match the originals, and then get all new rubber bushings and then get the adjustable upper control arms that were an option on some Alfas, and then re-adjust your camber a bit, and then get yourself some highly sticky DOT legal sticky tires in a 185/70-14 size, and then take her back out on the track...you would notice a BIG difference! Not that I (or any other Alfisti) have ever done anything like that, you understand?
Cheers,
Alex Csank
Chair, Alfa Century 2010 - The AROC USA ALFA Centennial Convention
E-mail: alfaromeodriveralex@gmail.com or alfacentury2010@gmail.com
Mobile: (757) 636-9513
82 Spider Veloce (Desideria - Kathleen's)
84 GTV6 Maratona (Mona - resto project)
88 Milano Verde (Trogdor The Burninator)
"My name is Alex and I am an Alfaholic."
Alfisti are always welcome in our home!
Old 10-16-2003, 07:55 PM
NikosF's Avatar
NikosF NikosF is offline
Hey Alex,
I see in your sig that you are selling your Spider. Just curious why you are selling - if I recall, you were talking earlier about dropping in a 2L. Canadian weather going to be too limiting for a convertible?
Nick
1967 Duetto 1600
Old 10-16-2003, 08:59 PM
Alex Csank's Avatar
Nikos,
No, I have had lots of fun in my Spider, and I will keep her if nobody buys her. I have owned her for almost five years now, and I have done lots of work to her and I really enjoy her. Unfortunately, I have lots of other Alfas that also need my attention, and I am getting more focused on what I want in my stable. The '69 Spider is a great car, but lacks the amenities of a later model Spider, while she also doesn't have the 'no-holds barred' handling prowess of a GTV, for example.
So, what I really want is to:
a. fix-up my GTV to be a track and occasional road car.
b. use my Milano Verde as a long-distance car.
c. buy a GTV6 as a daily driver
d. buy a more modern Spider ('86-'89) for convertible days.
e. give my Milano Gold to my son.
f. buy a 164L to use in the winter
Does that make any sense to you?
Cheers,
Cheers,
Alex Csank
