Here is a shot of my new family member on her way home. Many thanks to Elcid Arana's (Previous owner and restorer) for all his help in getting her ready for the trip home. As you can see, Elcid took great care in preparing her for the trip. I cannot say enough about Elcid, the perfect kind of guy to buy a car like this from. He truly cares and has put his all into this GTV! Bravo Elcid!
Lots of you gave been asking who and how they painted my GTV.
CUSTOM CLASSICS BY AUBREY in Lancaster California did the painting. Below us a detailed description of exactly what they did.
Set car on rotisserie
Clean underside of car
Deliver car to media blasters
Pick up car from media blasters
Check complete body for primer
Repair body as needed ( this is a separate charge hot on estimate)
Fit doors, hood and deck lid
DP90 complete body shell inside and out (etching primer)
K36 complete body shell inside and out (Hi-build primer)
DP90 doors, hood and deck lid (etching primer)
K36 doors, hood and deck lid (Hi-build primer)
DP90 engine compartment and underside of body (etching primer)
K36 engine compartment and underside of body (Hi-build primer)
Guide coat and block sand complete body shell
Guide coat and block sand doors, hood and deck lid
Guide coat and block sand engine compartment and underside of body
K36 complete body shell inside and out for final time
K36 doors, hood and deck lid for final time
K36 engine compartment and underside of body for final time
Guide coat and block sand complete body shell for final time
Guide coat and block sand doors, hood and deck lid for final time
Guide coat and block sand engine compartment and underside of body for final time
Seal and paint complete body shell color chosen by owner (7 coats Concept urethane)
Seal and paint doors, hood, engine compartment and deck lid color chosen by owner (7 coats Concept urethane)
Seal and paint with body color or semi gloss black underside of body (owner will choose)
Wet sand complete body shell with 1,500 and 2,000 wet or dry
Wet sand doors, hood and deck lid with 1,500 and 2,000 wet or dry
Polish body shell with heavy duty, medium and fine compound
Polish doors, hood and deck lid with heavy duty, medium and fine compound
Install doors hood and deck lid
Detail body for delivery
Costs for this work is between $9,000 and $10,000
The painting of the underside of the car body color adds about $800 to the cost
The painting of the underside of the car body semi gloss black is part of the paint job at no extra cost
Body work if needed will cost more the owner will be given extra work in writing
Related Threads
Alfa Romeo Forums
2.1M posts
88.6K members
Since 2002
