Old 09-01-2005, 11:55 AM
kengta's Avatar
kengta kengta is offline
Another MONO Sleeve
Here are some Pics of a Mono Sleeve I got in the early 1980's as part of deal for 1966 Sprint GT club racer that I purchsed. I may have been race in that or another chassis, a 1969 GTV, in CASC Ontario region B-sedan events.
The block is a 1750 base.
The head came with it and the pistons.
The 1750 head has a sleeved manifold with Aeoquip fittinga wellded on it. The sleeves protude als insert into the resesses in the head. The valves Are GTA.
Ken Geiger, Toronto
1965 GTA, RHD, Corsa, Trans/Am 66-72
1966 Sprint GT, B-Sedan in 70's
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
Old 09-01-2005, 11:56 AM
kengta's Avatar
There is aglitch on uploading the pics so I post Soon
Ken Geiger, Toronto
Old 09-01-2005, 12:15 PM
borrani's Avatar
borrani borrani is offline
you TEASE!!!
Old 09-02-2005, 06:23 AM
kengta's Avatar
First -Left side
Second -Right Side
third -Top
Fourth - S/n AR00548*A3547*
Ken Geiger, Toronto
Old 09-02-2005, 06:29 AM
kengta's Avatar
Note the water passage work, some blocked, some sleeved and drilled out.
head has GTA Valves and valve angles and gear.
Ken Geiger, Toronto
Old 09-02-2005, 06:35 AM
kengta's Avatar
Intake manifold showing protruding sleeves which has been matched to the head. I guess they bolted the manifold to the head, bored through each port into the head. Inserted the sleeve and locked it to the manifold at least using set screws. the ported the manifold.
Ken Geiger, Toronto
Old 09-02-2005, 06:38 AM
kengta's Avatar
Re the first set of pics, block right is left and vica versa. I usually know which is which.
Ken
Ken Geiger, Toronto
Old 09-02-2005, 11:50 AM
gtaj gtaj is offline
ken those are nice. what are you going to do with them?
Old 09-02-2005, 12:37 PM
kengta's Avatar
These MONO sleeve parts have seen the light of day twice in the last 25 years and I packed them away again last night. Remember the ending of "Raiders of the Lost Arc".
Seriously, I have no immediate plans but I might add, every thing is for sale at the right price. Interested?
Yours in Mono Sleaves
Ken Geiger, Toronto
Old 09-02-2005, 01:02 PM
borrani's Avatar
Remarkable how the spark plug hole intersects the valve seats. Better be careful not to run too tall a spark plug!
What's a standard head thickness, 4.412"? This sucker's cut way down if that's the case!
Steve S.
Old 09-03-2005, 12:31 AM
Biscione's Avatar
Biscione Biscione is offline
What is the bore of the monosleeve?
Biscione
Old 09-07-2005, 05:59 AM
kengta's Avatar
Biscione
The bore of this Mono sleeve is 84 mm.
Regards
Ken
Ken Geiger, Toronto
