Go Back   Alfa Romeo Bulletin Board & Forums > General Forums > Picture Room
  #61 (permalink)
Old 08-03-2005, 04:41 AM
cucinando's Avatar
cucinando cucinando is offline
Send a message via Skype™ to cucinando
Originally Posted by smestas
I did a quick search here on the BB and a few phone calls to the Rimicci household ...
And which one was more effective?!?!?
Maybe if you publish the Rimicci household (help-line) phone number, we wouldn't have the "don't know how to search, I'll start a new thread" problem!!
It sounds like you got it bad, and that's good.
P.S. Do change all those lines before you blow yourself up.
Gavin Cooke
'72 GTV 2000 (sold to a good home)
'70 GT Junior 1300 (suddenly a project car )
'00 156 Sportwagon 2.0 TS (daily)
  #62 (permalink)
Old 08-04-2005, 09:28 PM
Alfapaulic's Avatar
Alfapaulic Alfapaulic is offline
congrats
What a great find, and now the fun starts...
Paul
76 Spider
71 Spider & many parts
67 BSA
  #63 (permalink)
Old 08-18-2005, 03:22 PM
mtaylor mtaylor is offline
Originally Posted by elite38868
Hurray!!! Good job Simon! Can't wait to see her get restored. And now you can post questions on your own forum! hehe.
The best of luck to you! Can't wait to see the finish.
Cheers.
Haha! Finished..... ohhh man.... that's a good one
What up Seeemon Leeemon!
  #64 (permalink)
Old 08-18-2005, 03:59 PM
smestas's Avatar
smestas smestas is offline
Admin
Administrator
Send a message via AIM to smestas Send a message via Yahoo to smestas Send a message via Skype™ to smestas
Welcome to the BB Taylor!! All about the RayShing.
Simon Mestas
Currently Alfaless | Classic Forums | Become an AlfaBB Subscribed Member
  #65 (permalink)
Old 08-18-2005, 04:03 PM
We need to do some serious RayShing on the Alfa.... so you can keep up with me in the humble sentra
  #66 (permalink)
Old 08-26-2005, 01:56 PM
geh458's Avatar
geh458 geh458 is offline
Simon,
I sent you a PM but haven't heard back from you, so how about an update on your project? Any chance you'll be at the AROSC School next weekend, with or without the car?
Gifford
'67 GTV --> SOLD, '72 Super
  #67 (permalink)
Old 08-27-2005, 11:07 AM
smestas's Avatar
Admin
Administrator
Gifford,
Apologies for the no reply to your PM. I was in Monterey image editing land for the last week or so. Whew!
Anyways the car is in no way even street safe right now although I have got it started and made a few victory laps around the neighborhood . I wish I could take it to the Willow Springs event but the list of things to fix and buy is too large to tackle right now. I did get her running but I need some new rubber for test driving before I can start to make better evaluations of what needs to be fixed first. I just finished getting a new clutch pivot arm which was the culprit of my clutch pedal hanging low. I bought a heavy duty customized one from BB member "ortak". I'm very pleased with the part and it works like a charm.
Here is my short list just to get her street safe and drivable.
  • new brake rotors and pads - current rotors are rusted over and were barely stoping the car when I drove it ?
  • new tires - still haven’t decided on the right size?
  • new gas tank - current one is leaking badly into the trunk
  • need to address a low oil pressure signal - previous owner said he thinks the car has lost a crank shaft plug?
  • new rear quarter panels rubber - windows right now just fall out
  • fix door handles - every time you close the doors there locked and the owner only gave me keys for the ignition.
  • change the rear diff fluid - I'm still waiting on my dad to bring me a 14mm hex tool
  • Need to figure out why there is coolant falling from under the dash onto my feet. I do remember seeing a picture of "roadtrip" with a similar problem.
Man I got a lot of work ahead of me and that’s just my short list.
Simon Mestas
  #68 (permalink)
Old 08-27-2005, 11:34 AM
jpv's Avatar
jpv jpv is offline
Check the heater water valve. The leaking must come from there... It's on the left side of the heater right behind the ignition key...
Joćo Vale
1969 Alfa Romeo GT 1300 Junior
1972 Alfa Romeo 2000 GT Veloce
1976 Porsche 924
1991 Mazda Miata MX5
  #69 (permalink)
Old 08-28-2005, 12:34 AM
chasking's Avatar
chasking chasking is offline
[*]need to address a low oil pressure signal - previous owner said he thinks the car has lost a crank shaft plug?
I'm going through the same process as you with my recently-purchased '71 GTV and I'm also getting a low oil pressure light when it doesn't seem like I should. One of the local club guys thought it was probably the sender. It can be checked with a relatively inexpensive mechanical gauge, and if that is indeed the problem, it will be a hell of a lot easier to deal with than replacing a crank plug.
Hmm... I sure hope it's the sender (in both our cases)!
Chuck King
1971 GTV 1750
1973 Berlina
  #70 (permalink)
Old 08-28-2005, 04:26 AM
jpv's Avatar
jpv jpv is offline
I think if the crank shaft plug was gone the engine wouldn't have any oil pressure AT ALL.
Is the oil pressure low at idle but it rises with the revs? - It could be the pressure relief valve jammed open.
The pressure is low trough out the rev range? - Worn oil pump.
just my 2 cents...
Joćo Vale
1976 Porsche 924
  #71 (permalink)
Old 08-28-2005, 10:07 AM
smestas's Avatar
Admin
Administrator
This is exactly what it is doing. Now where do I find that pressure relief valve.
Simon Mestas
  #72 (permalink)
Old 08-28-2005, 08:50 PM
jpv's Avatar
jpv jpv is offline
The pressure relief valve is built in the oil pump. It's a small piston with a spring. You have to take the oil pump off and check that piston.
It could be jammed due to a scored piston or liner...
You could need a new oil pump.
Normaly to take the oil pump out is an engine out job. But if you have access to the right tools you can take it out without removing the engine. Talk to Anthony. To reach the oil pump you have to remove the lower pan of the oil sump.
Joćo Vale
1976 Porsche 924
  #73 (permalink)
Old 08-28-2005, 08:57 PM
jpv's Avatar
jpv jpv is offline
This is the oil pump and you need to check out the thin in the second picture. Just remove the pin and the piston and spring comes off.
Joćo Vale
1976 Porsche 924
  #74 (permalink)
Old 09-09-2005, 01:01 AM
smestas's Avatar
Admin
Administrator
JPV,
Thanks for the advice and the images! I'll let you guys know what happens once I have time to debug it.
Untill then here is a before and after picture of the engine bay. The cleaner of the two is after I sprayed some lubricant all around to try and stop some of the surface rust that had built up from sitting for so long.
Simon Mestas
  #75 (permalink)
Old 09-09-2005, 01:02 AM
smestas's Avatar
Admin
Administrator
Anyone notice that I lost one of my brake reservoir caps.
Simon Mestas
Digg this Post!Add Post to del.icio.us
