Flaminia Coupé -the Bugatti-Wagen- - Page 16 - Alfa Romeo Bulletin Board & Forums
 11Likes
post #226 of 236 (permalink) Old 02-24-2017, 01:27 PM
If I may, the design for construction of the door is a PF design, not a Lancia design.
That said, I have had a few PFs, and seen many others. When they are right they look and feel magnificent, but metal gets tired. Door sag can be an issue, and poor refitting, with one
corner not quite flush, absolutely spoils the surface.
That won't be the case for Hubert....
As to what is "really required", that's rather subjective, no? Myself? I'd favorably compare Lancia engineers against most contemporaries.
B24Spider is offline
post #227 of 236 (permalink) Old 02-24-2017, 02:42 PM
From my perspective it is nice to see something whereby pure function is not the sole criteria. Those inner pieces of the door ensure strength and that tank like feeling by reducing movement on a large door at time of striking closed. The holes strengthen (and marginally reduce weight) plus they look good. A cheaper car would have had just W beams for reinforcing and nowhere near the number of pieces within. Nice to see something made by artisans - like yourself Hubert. Done for form and feel with no CAD. Not necessarily the most efficient way but who cares - tactility and form rules and keeps these art pieces interesting forever.
Richard J
'65 Giulia Ti, '69 GT Junior, '74 2000 GTV, '76 Alfetta GTV, '77 Alfetta GTV.`00 156
alfavirusnz is offline
post #228 of 236 (permalink) Old 02-25-2017, 07:18 AM
bmarler's Avatar
actually, from a structural standpoint the door is a very good design. the diagonal brace from the bottom hinge area provides support for the trailing structure of the door. as long as the a pillar is intact, that door will fit the opening perfectly. i love it.
brian
s1 fulvia sport, s3 appia vignale
bmarler is offline
post #229 of 236 (permalink) Old 02-26-2017, 04:50 AM Thread Starter
Tedesco's Avatar
After collecting tips and tricks from various sources, today was the day to try my first complete door skin on the English wheel. It is not finished yet, but the result achieved so far is absolutely promising. One key statement was, if you understand what you (resp. the machine) do to the material and see how it reacts (the result), you gain control and when you have control you have all you need. Maybe i am at 80% control and 20% coincidence by now.
No coincidence but simply a little bit of carelessness was the use of the vise grips causing some dents. Luckily these could be easily rolled out.
Now the bead roller has to be delivered even faster, because the bead at the door skin needs to be made with it!
Hubert
Flaminia GT 3C, Flaminia Convertibile 3C, Flavia Convertibile 1.8, A112 Abarth, Flaminia Coupé 2.5, Fulvia Sport 1.3S
Tedesco is offline
post #230 of 236 (permalink) Old 03-02-2017, 11:11 AM Thread Starter
Tedesco's Avatar
Octopus
While waiting for the new equipment, there was some spare time to make a new and very useful tool. It is not my idea, but it is "freeware".
The original device has four arms, but is mounted on a slightly wider base plate. Mine had to be made of material "off the shelf". The plan was to fix it on a stand so that it can be necked. The aluminum rod used for the hinges was good for making eight arms, so two semi-octopusses were made.
For the first test, a front wing was mounted to them. It is obvious, that the wing would be a bit too big for only one of the devices, whereas the two of them fix it perfectly while it sits on the table. One could think about a versatile base, allowing to put the two base plates in different distances.
Hubert
Tedesco is offline
post #231 of 236 (permalink) Old 03-02-2017, 02:48 PM
NMMilano's Avatar
Looks like artwork
87 Milano Platinum
76 Alfetta GT race car
70 Fulvia 1.3 Rally S
68 Fiat 850
NMMilano is offline
post #232 of 236 (permalink) Old 03-03-2017, 04:49 AM
Mark_toro's Avatar
Hubert's whole place looks like artwork - love this thread
84 Spider - Long gone, but started the addiction; 85 GTV6 - Current project, Supercharged, Mega Squirt; 88 Verde - "Milo" It has a name, must be a keeper
Mark_toro is offline
post #233 of 236 (permalink) Old 03-09-2017, 10:27 AM Thread Starter
Tedesco's Avatar
I see a face. The radiator grill fits quite well, maybe a little bit of fine tuning at the driver´s side . . .
Hubert
JCDK and PhilBoncer like this.
Tedesco is offline
post #234 of 236 (permalink) Old 03-09-2017, 06:27 PM
So Hubert how are you going to alter that opening on the drivers side? Will you remake it or hammer it back and then reform, or will you build it up with lead and file form it?
Its looking good. Amazing from where you started from.
Richard J
post #235 of 236 (permalink) Old 03-10-2017, 01:44 AM
Another milestone!
Seeing this I feel very privileged owning a original solid and rustfree car! (At least, let me think it is... underneath the paint...)
Keep up the great work!
Jones is offline
post #236 of 236 (permalink) Old 03-10-2017, 02:56 AM Thread Starter
Tedesco's Avatar
Richard, the grill is not positioned properly yet, it might come by 1 or 2 mms. Panelwise the new parts are exactly where the old were. They formed the mouth of the grill using a lot of lead which had been removed when rebuilding that part. It is ok to do it the same way, I think. At least it´s worth a trial.
Jones, keep yours dry and enjoy it!
Hubert
Tedesco is offline
