Old 02-19-2005, 06:31 AM
magista's Avatar
Send a message via AIM to magista
Group 2: Rant and Rave!
I just want to take this opportunity to give a rave review to Group 2. We all know they are great but I'm going to talk 'em up some more.
I brought my Berlina in for some badly needed work. The front end was good and sloppy. I called up Group 2 and Joe said "Bring it in!" I did, Chris and I went through it while it was up on the rack. One of the first things found was the brake master was toasted (No Chris, I was not trying to secretly kill you while out on the diagnosis run). Other items included sagging springs, shot tie rod ends, shot trunnion bushings, shot control arm bushings, shot axle straps, shot front and rear trailing arm bushings and old Konis in sad shape (the shafts were rusting through).
We found some other items that we will address during round two as well.
The Group 2 guys are very personable, helpful and knowledgable. They are just top notch. Period. It's always nice to hear from the garage working on your car that it will be "fun" to work on. You know it's in good hands.
I took the car for a test run and I'll tell you the difference was like night and day. They made that car drive like a Chariot of the Gods. They gave me new poly bushings, Shankle springs, Bilstein shocks and a new brake MC. They also changed the oils, tie rod ends and axle straps.
The only thing left is to level out the rear end as the new springs sit just a tad high. Once I got the car back I drove to work everyday that week just to have an excuse to drive it. I usually ride the bus or walk. It's a truly amazing little beasty now and I'll use any excuse to drive it anywhere.
I cannot emphasize what great work they do. I can't wait to take my TI in to them. Joe, Chris and the rest of the crew are exceptional. Group 2 rules the school!
'08 Ducati Sport 1000 'El Duce'
Old 04-04-2005, 06:24 PM
GianniB's Avatar
I'll add a big second to Damian's rave for Group 2. They are great. Just had them mount and balance some new tires for the GTV, I've also used them to align it, and some brake and suspension work. Chris does first class work and they let you hang out in the shop while the work is done. I'll be taking the MINI there too for its first oil change.
Cheers,
John
Bothell, WA
