Amp meter idea - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 06-06-2016, 09:55 PM Thread Starter
Hans-Peter's Avatar
Amp meter idea
Idea for Tim
Hans-Peter is offline
post #2 of 3 (permalink) Old 06-07-2016, 05:10 AM
Hi Hans,
I have the console from a Berlina and the two air vents from a Super Nouva as shown in the picture. Wanted to get more ventilation in the cabin to help with our hot summers.
I am wanting a clock and amp meter to fit in the two lower gauge holes.
Thanks for the picture of the gauges you have, the clock looks about right, can you tell me what size the clock body is (ie what hole size is needed to fit it). I would be interested in the clock even if it does not work.
The Amp meter could be made by using an alfa water or fuel gauge body and fit a similar looking amp meter mechanism....any suggestions?
Cheers Tim
Rosey105 is offline
post #3 of 3 (permalink) Old 06-07-2016, 10:11 PM Thread Starter
Hans-Peter's Avatar
Clock is Berlina 1750 , body is 50mm , outside is 56mm , water is the same even though it looks different, amp meter body is also 50mm , I think its a standard size.
Replace with
