156 2.4 JTD Keeps cutting out
Hi, I am haveing persistant problem with my JTD, It will start and run straight away then suddenly engine stops?, It will then restart straight away after about 30 seconds then same happens again. but if you start then drive off and thrash it, itseems to run fine ? it has been on diagnostic and a low fuel pressure error message is present but been advised that this would be flagged up as engine stops anyway. I have also replaced intank fuel pump and relay, crank sensor fitted below startermotor and the fuel pressure sensor fitted at rear of high pressure mech pump on engine?. any ideas before i buy a jap car!.
Mick.
